AM3 Motherboard, Which CPU?
As the others have said, what features do you need? This has integrated graphics if you might have use for them and some other features you might use such as eSATA:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-356-AS&groupid=701&catid=5&subcat=1481
This would be better suited to Crossfire:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-366-AS&groupid=701&catid=5&subcat=1481
Or if you want to spend less have a look at the MSI 770-C45.
CPU not Motherboard
Best bang/buck i'd say at the minute is an Athlon II X4 620 which can be had for around £75. But as said it really depends on your usage, budget etc.
Then if budget isn't an issue, why not go for a Phenom II 965 or 955? They're the fastest two available.
