Hi,
I'm about to buy the components for my first build. It will be mainly used for movies and gaming, running two 1920 x 1080 monitors.
Here is the current spec:
CPU - AMD Phenom II x4 955 Black Edition 3.2GHz 8MB (Socket AM3) £160.99
http://www.overclockers.co.uk/showproduct.php?prodid=CP-244-AM
MOBO - Asus M4A78T-E AMD 790GX (Socket AM3) £98.99
http://www.overclockers.co.uk/showproduct.php?prodid=MB-335-AS
GPU - XFX 4890 XT 1GB £140.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-126-XF&groupid=701&catid=56&subcat=
RAM - OCZ Gold 6GB (3x2GB) DDR3 1333MHz £62.99
http://www.overclockers.co.uk/showproduct.php?prodid=MY-151-OC
PSU - Corsair TX 650W ATX SLi Compliant Power Supply £71.98
http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-CS
HDD - Samsung SpinPoint F1 1TB SATA-II 32MB (OEM) £59.99
http://www.overclockers.co.uk/showproduct.php?prodid=HD-053-SA
OPTICAL - LG GGC-H20L Lightscribe SATA BD-R HDDVD-R DVD-RW £79.99
http://www.overclockers.co.uk/showproduct.php?prodid=CD-074-LG
WIRELESS PCI CARD - Linksys WMP54G 54Mbps £22.99 (chosen this over cheaper models as has been proven to be compatible with W7 64bit)
http://www.overclockers.co.uk/showproduct.php?prodid=NW-003-LS
CASE - Antec 900 Ultimate (No PSU) £79.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-065-AN
TOTAL COST - £778.90
My questions are:
1) Are all the components compatible with each other, and with W7 64 bit?
2) If I am to overclock do I need to buy a CPU cooler?
3) Can you recommend any improvements / are there things missing (bar monitors / mouse / keyboard)?
Any help hugely appreciated ... trying to avoid as many mistakes as possible on my first build
My questions are:
otherwise looks like a nice machine
