AM3 or AM2
Permabanned
8 Jul 2010
hi i have bought a AMD bundle from ****** it comes with a GeForce6100PM-M2 v:3.0 motherboard, 2 gb of DDR2 ram and a AMD atholon II quad core. however i am wanting to buy a new motherboard but i need to find out what socket it is (AM2, AM2+, AM3) i will link a picture of the motherboard if that is any help
I appreciate the help
being DDR2 the motherboard could be AM2 or AM2+
but the cpu could be AM2 or AM3 (AM3 is backward compatible)
Be very clear about this :
- The CPU is AM3, it supports DDR2 and DDR3 & is backwards compatable with AM2+
- Your current motherboard is AM2+, it must be used with DDR2.
- An AM3 motherboard must be used with DDR3 Ram.
- If you buy an AM3 mothrboard you will also need to change your RAM to DDR3
So unless you want to do that, I would suggest getting an AM2+ motherboard again.
