am3+ or fm2 ?
Permabanned
25 Jul 2010
under
looking at building a pc.
the fm2 boards seem relatively cheap and good specs.
now do the cpu's overclock well or should i go down the am3 route.
i dont want to spend £150 on an intel cpu hence the amd section.
FM2 if you don't plan to have a dedicated GPU since they have wonderful onboard graphics. AM3+ if you plan to have a dedicated graphics card since the processing power is better.
I'm not entirely sure how well the FM2 APU's overclock, but I have heard a few people not getting "that high" clocks with them.
If you going a cheap performance root than I'd go for an AM3+ with an FX-6300. If you have a decent cooler you should get 4.5GHz+ out of it. Just make sure to buy a board with at least heatsinked VRMs or an 8+1 phase VRM.
already have a decent z68 board but only have a intel G550 cpu which i cant see being enough.
i was looking at a i3 2120
ok i managed to pick up a i3-2105 and a scythe Kozuti for £50.
could not turn that down.
hopefully it should be ok with the gtx 470
