AM3+ socket question????
Quick question whats the system for? :)
We would highly reccomend you stay AWAY from Bulldozer chips. If your going to go AMD get Piledriver. Even then they have limited use as the latest i3 chips can beat them in most instances.
AM3+ support the FX range, AM3, do not.
Cooler Wise, here would be somewhere to start. I am working on your £20-30 budget, other would most likely recommend something better:
YOUR BASKET
1 x Alpenföhn Brocken CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £32.99
1 x Arctic Cooling Freezer Xtreme Rev.2 High Performance Quiet CPU Cooler(Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £29.99
1 x Arctic Cooling Freezer 13 Pro Extreme Performance CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £26.99
Total : £100.46 (includes shipping : £8.75).
If your overclocking it, you'd want to spend an additional £20-30.
thanks for reply guys
The system isnt for gaming. Its for a music production. So an 8core cpu would be great.
Compared to the i5 system I speced for 500, the AMD seems like it would be better and cheaper.
hows this look
AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail
ASRock 970 Extreme3 AMD 970 (Socket AM3+) DDR3 ATX Motherboard
NZXT LeXa S Windowed Midi Tower Case - Black
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-10666C8 1333MHz Dual-Channel (CMX4GX3M2A1333C8)
Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM
YOUR BASKET
If your over-clocking it, you'd want to spend an additional £20-30.
What would be a good recommendation for a mild over-clock? (Asrock X-Boost, I might be a bit more adventurous when I have learned more about it :D )
I do not want to say "Money no object" but it is not a problem! I am happy to pay more for a better product.
(Also with a degree of future proofing. I currently have an 8150 but My intention is to eventually upgrade my current AM3+ board with the final iteration of AM3+ processor + mild OC when the time comes)
