AM4 Cooler
18 Apr 2020
Hi all.
My recently purchased 3600 run hot, too hot for my liking with the stock cooler and even under volting.. So I'm after some recommendations for an air cooler. Max price of around £50 would be ideal and according to my case spec can be no higher than 152mm. Unfortunately most non low-profile coolers I'm looking at are a few mm above this.
Any advice?
Thanks
Hi all.
Any advice?
Thanks
What temps are you seeing?
36-40 idle and ~95 under load. I've reseated the cooler with new paste just in case and temps are even across all cores. Reading this is pretty common with this chip and cooler combo.
