AM4 coolers, need some shopping help
22 Feb 2017
Portsmouth
Hi all,
Quick one - if I wanted to spend 30-40 on an AM4 cooler what's the best to go for? I will be OCing so best performance possible for my budget is needed.
Thanks all.
the stock cooler is good for a mild overclock, so unless you're going for max clocks, just stick to the stock cooler.
if you are going for max clocks, then don't cheap out on the cooler :)
do you want an air cooler or aio water cooler?
some bigger air coolers may have ram clearance issues depending on how tall your ram heatsinks are - just be aware
