*** *** Corsair Dominator XMS3 4GB (2x2GB) DDR3 1600C9D Twin3X @ £63.99 inc VAT *** ***
The TW3X4G1600C9D is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using Corsair’s latest high performance heat sink with Dual-Path Heat Xchange (DHX) technology. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at the low latencies of 9-9-9-24.
- Each module pair is tested together at 1600MHz
- Tested and packaged in pairs
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.80V, at latency settings of 9-9-9-24
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- 4096 Megabytes of DDR3 memory
- Two matched CM3X2G1600C9D modules
- Using DHX Dominator technology providing maximum cooling
- 100% tested at 1600MHz in high performance DDR3 motherboards
- Supports Socket AM3 AMD Phenom II processors
- Lifetime warranty
Just £63.99 inc VAT
BUY NOW
- Lifetime warranty
Just £63.99 inc VAT
BUY NOW
great offers though
