*** Amazing Memory Deals ***
Suspended
18 Oct 2002
OcUK HQ
*** *** Corsair Dominator XMS3 4GB (2x2GB) DDR3 1600C9D Twin3X @ £63.99 inc VAT *** ***
The TW3X4G1600C9D is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using Corsair’s latest high performance heat sink with Dual-Path Heat Xchange (DHX) technology. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at the low latencies of 9-9-9-24.
- Each module pair is tested together at 1600MHz
- Tested and packaged in pairs
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.80V, at latency settings of 9-9-9-24
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- 4096 Megabytes of DDR3 memory
- Two matched CM3X2G1600C9D modules
- Using DHX Dominator technology providing maximum cooling
- 100% tested at 1600MHz in high performance DDR3 motherboards
- Supports Socket AM3 AMD Phenom II processors
- Lifetime warranty
Just £63.99 inc VAT
BUY NOW
*** *** Kingston HyperX 6GB (3x2GB) Intel XMP DDR3 12800C9 1600MHz Tri-Channel Kit (KHX12800D3K3/6GX) @ £79.98 inc VAT *** ***
- Lifetime warranty- JEDEC standard 1.5V ± 0.075V Power Supply
- VDDQ = 1.5V ± 0.075V
- 667MHz fCK for 1333Mb/sec/pin
- 8 independent internal bank
- Programmable CAS Latency: 9-9-9-27 @ 1T
- Posted CAS
- Programmable Additive Latency: 0, CL - 2, or CL - 1 clock
- Programmable CAS Write Latency(CWL) = 9(DDR3-1333)
- 8-bit pre-fetch
- Burst Length: 8 (Interleave without any limit, sequential with starting address “000” only), 4 with tCCD = 4 which does not allow seamless read or write [either on the fly using A12 or MRS]
- Bi-directional Differential Data Strobe
- Internal(self) calibration : Internal self calibration through ZQ pin (RZQ : 240 ohm ± 1%)
- On Die Termination using ODT pin
- Average Refresh Period 7.8us at lower then TCASE 85°C, 3.9us at 85°C < TCASE . 95°C
- Asynchronous Reset
- PCB : Height 1.180” (30.00mm), single sided component
Just £79.98 inc VAT
BUY NOW
*** *** Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500C5 TwinX Dual Channel (TWIN2X4096-8500C5C) @ £37.00 inc VAT *** ***
The XMS brand family is Corsair's mainstream line of performance memory. These modules allow users to experience outstanding memory performance and stability.Simply pop in this 4GB 1066MHz CL5 DDR2 memory kit into your system and see the difference in performance. If you are looking for extra performance or reliability in your Intel or AMD DDR2 system, the Corsair 4GB 1066MHz DDR2 memory kit offers this solution!
- Density: 4GB (2x2GB Module)
- Speed: 1066MHz
- Timing: 5-6-6-18
- Type: DDR2
- Format: DIMM
- Pin Out: 240
- PinVoltage: 2.1V
- Lifetime Warranty with Corsair
Just £37.00 inc VAT
BUY NOW
*** *** Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK) @ £75.99 inc VAT *** ***
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 8-8-8-24 timings. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (8-8-8-24)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- Lifetime Warranty
- XMP Ready for Core i7 Processors
Just £75.99 inc VAT
BUY NOW
*** *** OCZ Blade Series 4GB (2x2GB) DDR2 PC2-9200C5 Low Voltage Dual Channel (OCZ2B1150LV4GK) @ £56.99 inc VAT *** ***
The Blade Series is the latest maximum-performance RAM designed specifically for the latest platforms. The Blade Series harnesses industry-leading speeds with the ideal combination of all the factors that formulate the ultimate memory solution— density, speed, latency, and an effective new cooling design—the Blade Series is guaranteed to please enthusiasts looking to take your system to new heights. The Blade heatspreader aims to enhance heat dissipation to improve the longevity and stability of the modules while keeping a sleek, low profile. The new propriety design has numerous channels that increase the surface area to more efficiently offload heat away from the memory chips and PCB. Push your gaming or overclocking rig to the extreme with the superior thermal solution and unmatched speeds of the high-end Blade Series memory modules. If seeking maximum frame rates in the latest PC titles or yearning for the highest benchmark record, the Blade Series was developed for gamers and overclockers looking to make the most of their high-performance systems.
- 1150MHz DDR2
- CL 5-5-5-18
- Unbuffered
- 1.80 Volts
- 1.85V EVP
- 240 Pin DIMM
- Pure Aluminum Heatsink
- OCZ Lifetime Warranty
Just £56.99 inc VAT
BUY NOW
*** *** OCZ Gold 6GB (3x2GB) DDR3 2000MHz PC3-16000C10 Low-Voltage Triple Channel (OCZ3G2000LV6GK) @ £93.99 inc VAT *** ***
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel Core i7 processor / Intel X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Just £93.99 inc VAT
BUY NOW
*** *** Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel (TWIN2X4096-6400C5C) @ £33.99 inc VAT *** ***
- Two matched 2GB modules for use AMD and Intel DDR2 systems
- Mainstream 800MHz solutions
- Latency of 5-5-5-18 for maximum reliability and performance
- XMS Heat Spreader
- Limited Lifetime Warranty
- Speed: 800MHz
- Timing: 5-5-5-18
- Type: DDR2
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.8V
Just £33.99 inc VAT
BUY NOW
*** *** OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel (OCZ3G1600LV6GK) @ £77.99 inc VAT *** ***
The OCZ PC3-12800 triple-channel memory kit designed specifically for the impending Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 3GB and 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Just £77.99 inc VAT
BUY NOW
is 12gb worth it in an i7 powered machine or would you see no real difference from 6gb?
edit: ignore that just seen the thread on exactly my question :)
how do the patriot vipers hold up against the dominators?
seeing how cheap these are i might get one, if its worth the change
The Viper is our best selling line at the moment. It is the one we use in all our overclocked i7 Bundles. Clocks really well
The last set of OCZ RAM looks tempting...I have the 1066 versions...and they are now OC'd to 1600+MHz...how high can the 1600MHz ones be overclocked to? Will this also enable high overclocks for my Core i7 920? Cos I can get to 4.5GHz but crashes when I load any apps in Windows...thanks :D
Is the Dominator above, ok in an MSI 790FX-GD70?
Would the Corsair Dominator TW3X4G1600C9D 2x2GB listed first be a good slection for an MSI 790FX-GD70 with an Phenom 955BE?
I was looking at the OCZ Platinum AMD Edition 2x2GB PC3-12800C7 1600MHz Dual Channel (OCZ3P1600LVAM4GK) (Stock code: MY-165-OC)but this is out of stock for two weeks.
Or if notthen any other suggestions.
Thanks, Colin
