*** Amazing Memory Deals ***
Suspended
18 Oct 2002
OcUK HQ
*** *** Corsair Dominator GT 6GB (3x2GB) DDR3 PC3-15000C7 1866MHz Triple Channel Kit (CMG6GX3M3A1866C7) @ £233.99 inc VAT *** ***
The DOMINATOR-GT is the ultimate performance solution within the DOMINATOR product line. Limited to only extremely high memory speeds, the Corsair DOMINATOR-GT only uses highly screened IC’s to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology, the DOMINATOR-GT modules also ship with the Airflow Fan to maximize heat transfer away from the modules– all the while being stable and reliable. With removable heat sinks, the DOMINATOR-GT modules can even be outfitted with additional upcoming accessories with enhanced features.
- Three matched 2GB modules for use in high performance Core i7 systems
- Outrageously fast 1866MHz performance
- Ultra-low 7-8-7-20 latency
- Dominator GT with rosso corso accents
- Includes Airflow fan for increased cooling performance
- Limited Lifetime Warranty
Only £233.99 inc VAT.
ORDER NOW
*** *** Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel (TR3X6G1600C8) @ £126.99 inc VAT *** ***
Corsair's value for performance 6GB 1600MHz CAS Latency 8 memory kit solution for the Intel Core i7 processor.
The XMS Series TR3X6G1600C8 G is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s new high performance heat sink. This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 8-8-8-24 at 1.65V VDIMM.
- New XMS3 Heat Spreader
- Matched Triple Kit
- 1600MHz
- 8-8-8-24
- 1.65V
- Lifetime Warranty
Only £126.99 inc VAT.
ORDER NOW
*** *** Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9) @ £117.99 inc VAT *** ***
The XMS Series TR3X6G1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £117.99 inc VAT.
ORDER NOW
*** *** Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £89.99 inc VAT *** ***
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
Only £89.99 inc VAT.
ORDER NOW
*** *** Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500C5 TwinX Dual Channel (TWIN2X4096-8500C5C) @ £74.99 inc VAT *** ***
The XMS brand family is Corsair's mainstream line of performance memory. These modules allow users to experience outstanding memory performance and stability.Simply pop in this 4GB 1066MHz CL5 DDR2 memory kit into your system and see the difference in performance. If you are looking for extra performance or reliability in your Intel or AMD DDR2 system, the Corsair 4GB 1066MHz DDR2 memory kit offers this solution!
- Density: 4GB (2x2GB Module)
- Speed: 1066MHz
- Timing: 5-6-6-18
- Type: DDR2
- Format: DIMM
- Pin Out: 240
- PinVoltage: 2.1V
- Lifetime Warranty with Corsair
Only £74.99 inc VAT.
ORDER NOW
*** *** OCZ Gold Edition 4GB (2x2GB) PC2-6400C5 Dual Channel Series (OCZ2G8004GK) @ £64.88 inc VAT *** ***
As part of OCZ’s Gold series, the PC2-6400 2GB modules deliver the performance and speed gamers require for today’s graphic-intensive DirectX 10 PC games. At 800MHz, the 2GB Gold Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide excellent memory bandwidth and deliver the best possible gaming and productivity on Vista systems.
All Gold Edition modules are 100% hand-tested for quality assurance and compatibility and feature high quality, gold-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ Gold series module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.1V ± 5% without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- Gold XTC* Heatspreader
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Only £64.88 inc VAT.
ORDER NOW
*** *** Corsair XMS2 2GB (1x2GB) DDR2 PC2-6400C5 Memory Module (CM2X2G6400C5B4) @ £29.98 inc VAT *** ***
The CM2X2G6400C5B4 is a 2048MByte DDR2 SDRAM DIMM. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been veried to operate at 800MHz at the low latencies of 5-5-5-18.
- Each module is tested at 800MHz
- Tested and packaged immediately following system test
- Tested at JEDEC standard latency settings (5-5-5-18) at 1.9V
- SPD programmed at: JEDEC standard 5-5-5-18 values at 800MHz
- 2048 Megabytes of DDR2 memory
- 100% tested at 800MHz in high performance DDR2 motherboards
- Legendary Corsair reliability and service
- Lifetime warranty
Only £29.98 inc VAT.
ORDER NOW
*** *** Crucial Value 2GB (1x2GB) DDR2 PC2-6400C6 Single Module (CT25664AA800) @ £28.99 inc VAT *** ***
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other. 240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast. Each 240-pin DIMM provides a 64-bit data path. Standard DDR2 240-pin DIMMs are available in DDR2 PC2-3200 SDRAM, DDR2 PC2-4200 SDRAM, DDR2 PC2-5300 SDRAM, and PC2-6400 SDRAM. To use DDR2 memory, your system motherboard must have 240-pin DIMM slots and a DDR2-enabled chipset. A DDR2 SDRAM DIMM will not fit into a standard SDRAM DIMM socket or a DDR DIMM socket.
- DDR2 PC2-6400
- CL=6
- Unbuffered
- NON-ECC
- DDR2-800
- 1.8V
- 256Meg x 64
- Lifetime Warranty
Only £28.99 inc VAT.
ORDER NOW
Heh :)
They might be competitive with current prices (I haven't checked), but I'm sure most people remember quality memory at ~£12/GB not so long ago.
i bout 2gb corsair value for 16 pound in march
By 'Quality' I was talking PC2-8500 / PC3-12800 in the moderately recent past (not long before i5 launched), obviously there was a short period a while back where you could get e.g. 4GB PC6400C4 for under £40.
this is true, there was a point where it was all just silly-cheap. Even prices in the MM have risen to around £60 for 4gb of PC8500
Yep 4GB PC2-8500 (2x2GB) Buffalo Firestixx for £39 + free postage, and then you had the 3x2GB Patriot Viper kits for about £75 as well.
Aaagghhh!!Thought RAM prices were coming back down, well for DDR2 anyway. Glad I stocked up on the £13 2gb strips when I did months ago.
