*** Amazing OCZ Triple Channel DDR3 Kit Deals ***
Suspended
18 Oct 2002
OcUK HQ
Hi There,
***OCZ Gold 6GB (3x2GB) DDR3 2000MHz PC3-16000C10 Low-Voltage Triple Channel (OCZ3G2000LV6GK)***
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel Core i7 processor / Intel X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Buy Now @ Just £97.99 Inc VAT
Hi There,
***OCZ Reaper 6GB (3x2GB) DDR3 PC3-15000 (1866MHz) Tri-Channel (OCZ3RPR1866C9LV6GK)***
The OCZ PC3-15000 triple-channel memory kits are designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. The Reaper HPC Series makes use of an innovative cooling solution to more effectively dissipate heat produced by high-speed memory, and offers superior cooling technology to ensure superior stability and performance over the entire life of the memory. The thermo-conductive copper heat pipe conduit is ideal for overclocking where every degree matters, ensuring that your cutting-edge investment will maintain its integrity throughout the toughest gaming missions, overclocking, or intense program applications. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
- 1866 Mhz
- CAS Timings: 9-9-9-28
- Reaper HPC Heatspreaders for excellent cooling
- 1.65Volts
- Lifetime Warranty
Buy Now @ Just £99.99 Inc VAT
Hi There,
***OCZ Gold 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel (OCZ3G1600LV6GK)***
The OCZ PC3-12800 triple-channel memory kit designed specifically for the impending Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 3GB and 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Buy Now @ Just £70.99 Inc VAT
Hi There,
***OCZ Gold 6GB (3x2GB) DDR3 PC3-10666C9 Low-Voltage Triple Channel (OCZ3G1333LV6GK)***
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 3GB, 6GB, and 12GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Available in 3GB, 6GB, and 12GB Triple Channel Optimized kits
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Buy Now @ Just £62.99 Inc VAT
