Get yourself ready for summer with some watercooling deals, bargains to be had here for this weekend only!
I am looking at doing one of these every couple of weeks, depending on what sells and what is suggested I am more than happy to try and get a deal for the next offer. Please feel free to suggest products you would like to see on the next one and I will see what I can do.
Theses deals are only for this weekend only so if you are looking at anything you will have to be quick, once I have had my morning drink on Monday these offers will be rapidly taken off!
Without anymore rambling from me, here is what you looked at this thread for.
Zalman Reserator XT Hybrid Liquid Cooling System - Black
The Zalman Reserator XT is a complete external liquid cooling system for your CPU with an extensive feature list including a warning and alarm system, comprehensive visual monitoring display, pure aluminium casing, double ball bearing fan, automatic on/off sync with the PC, and much more. Powerful and convenient cooling at a low noise level.
- High performance ultra quiet water cooling system
- Active/passive hybrid cooling design
- Automatic/manual fan speed control modes
- Coolant flow & low-level warning alarms
- Automatic on/off when PC is switched on/off
- Supports 754/939/940/AM2/LGA775
Previously sold for: £224.99+VAT
Price: £219.99+VAT (£258.49 inc VAT)
BUY NOW!
CoolIT Freezone Elite TEC/Chiller CPU Cooling Unit
Freezone Elite is a CoolIT Systems Inc. patented product that removes heat from individual components and transfers the heat outside the computer case.It combines facets of air-cooling and liquid chilling through purpose-designed internally installed components. It can aggressively remove heat from a computer quietly, efficiently, and reliably. This system alleviates any risk of condensation, is highly effective, and is easy to install. To provide concentrated cooling of a small surface area, Freezone uses environmentally friendly liquid coolant as the primary dissipating medium, which absorbs heat much more efficiently than air. The patented system configuration includes multiple TECs (thermoelectric coolers) that provide unique liquid chilling for superior thermal performance. In addition to keeping the CPU cool, Freezone actually provides cooling for other vital components while improving system level acoustics. By removing heat from the source and transferring it outside of the chassis, internal PC temperatures are held low. This removes the need for multiple case fans, which eliminates unwanted noise and improves the reliability of other peripheral hardware such as the hard drive. The Freezone Elite CPU Cooler includes: a Chiller / Pump Module, the MTEC™ Control Center, and a CPU Fluid Heat Exchanger (FHE). This universal sealed closed-loop maintenance free system is pre-plumbed and charged for simple bolt-in installation. The Freezone Elite is designed with todays Quad Core Processors in mind and has a thermal dissipation potential of around 250W
- CPU FHE (Fluid Heat Exchanger)
Design: Monolithic copper, multi-cell
Dimensions: 43 x 42 x 16.5 mm
Weight: 175g
- MTEC Control Center Module : Full featured system status monitor and control module.
- Heatsink Design: Dual dissipation plate, anodized alloy
- TECs
Power usage: Max total 72 Watts
Design: Six solid-state heat pump wafers
- Chiller FHE’s Design: Dual anodized alloy distribution, multi-channel
- Fan
Airflow: 120 CFM
Noise: Max 40 dBA
Bearing Type: Dual ball
Life Cycle: 50,000 hrs
Features: 3rd Wire Tachometer
Previously sold for: £245.99+VAT
Price: £215.99+VAT (£253.79 inc VAT)
BUY NOW!
Swiftech H2O-220 Apex Ultra+ Watercooling Kit (Socket 462/478/LGA775/754/939/940)
The Apex "Ultra+" is a complete system cooling solution, including CPU, GPU, and Chipset water-blocks. The kit is a declination of the H20-220 Apex Ultra liquid cooling kit which covers CPU cooling only. The Apex Ultra+ includes everything that comes in the Apex Ultra plus the MCW60 VGA kit itself including GPU water-block and MC14 Ramsinks, as well as the MCW30 Chipset water-block.
- Apogee CPU Block
- MCW60 VGA Block
- MCW30 Chipset Block
- MCR220 Radiator
- MCP655 12V DC Pump
- MCRES-MICRO reservoir
- MCB120 Radbox radiator mounting adapter
Previously sold for: £171.99+VAT
Price: £149.99+VAT (£176.24 inc VAT)
BUY NOW!
BUY NOW!
Weight: 175g
- TECs
- Fan
Airflow: 120 CFM
Noise: Max 40 dBA
BUY NOW!
- Apogee CPU Block
- MCW60 VGA Block
- MCR220 Radiator
BUY NOW!
