Amazing Weekend Special Deals - Great Offers Inside!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
For this weekend starting now and ending midday Monday we have some cracking deals for you on selected product lines:-
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
with four cores and high scores, the intel® core™2 professional processor q6600 is flat out the most extreme desktop processor. it’s specifically built for hardcore enthusiasts who don’t take kindly to compromise. based on the core™ microarchitecture, the intel® core™2 professional q6600 is the ultimate multimedia engine and multitasking king. the performance? it eats benchmarks for breakfast. this energy efficient version consumes 10w less power than the traditional q6600 which means it produces less heat and is better suited for overclocking purposes.
- quad core technology
- slacr stepping, 95w
- energy efficient edition (consumes 10w less power, less heat, better overclocking)
- 2.40ghz clock speed
- 8mb l2 cache
- intel speedstep technology
- em64t 64-bit technology
- execute disable bit
- cooler running technology, less heat and less noise!
- supplied with intel referance heatsink & fan
previously sold for: £121.99+vat (£143.34 inc. vat) (saving you £9.40)
price: £113.99+vat (£133.94 inc vat)
buy now!
ocz 2gb ddr3 pc3-14400c8 1800mhz platinum (2x1gb) dual channel ddr3 (ocz3p18002gk)
tested and qualified to reach ddr3-1800 with ample overclocking capability and aggressive latencies, the ocz pc3-14400 platinum edition is a true milestone. at 1800mhz, the ocz pc3-14400 modules are rated to run cl8-8-8 to take the latest intel platforms to previously unimaginable levels. ocz platinum ddr3-1800 modules will be available in 1gb modules and 2gb (2x1024mb) dual channel kits. ocz has been working closely with the leading platform providers to ensure optimal performance and compatibility on all the next generation computing platforms that will be introduced later this year. each module is 100% hand-tested for quality assurance and compatibility and features a proprietary platinum-mirrored xtc (xtreme thermal convection) heatspreader for the most effective heat dissipation. as part of ocz’s line-up of premium memory, the ddr3 series is backed by a lifetime warranty and industry-leading technical support for unparalleled peace of mind.
* xtc (xtreme thermal convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. in this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. at the same time, mechanical stability is maintained.
- 1800mhz ddr3
- cl 8-8-8-24
- unbuffered
- platinum z3 xtc heatspreader*
- lifetime warranty
- 1.9volts
- 240 pin dimm
- optimized for asus boards
previously sold for: £199.99+vat (£234.99 inc. vat) (saving you £94.00)
price: £119.99+vat (£140.99 inc vat)
buy now!
corsair 2gb ddr2 xms2 dhx pc2-6400c5dhx twinx (2x1gb)
the twin2x2048-6400c5dhx is a 2048mbyte matched pair of ddr2 sdram dimms built using corsair’s latest high performance heat sink with dual-path heat xchange (dhx) technology. this part delivers outstanding performance in the latest generation of dual-channel ddr2-based motherboards. it has been tested extensively in multiple ddr2 motherboards to ensure compatibility and performance at its rated speed. this memory has been verified to operate at 800mhz at the low latencies of 5-5-5-15.
every part is tested in corsair's factory at 800mhz, but your actual results may vary depending on the overclocking margin of your cpu and motherboard. newer motherboards may be used for production test as they become available. corsair may periodically update the part with newer ram revisions of same or greater performance. ram used on the module may change without notice. © may 2007 corsair memory, inc.
previously sold for: £34.99+vat (£41.11 inc. vat) (saving you £8.22)
price: £27.99+vat (£32.89 inc vat)
buy now!
corsair 2gb ddr2 xms2 dhx pc2-6400c4dhx twinx (2x1gb)
the twin2x2048-6400c4dhx is a 2048mbyte matched pair of ddr2 sdram dimms built using corsair’s latest high performance heat sink with dual-path heat xchange (dhx) technology. this part delivers outstanding performance in the latest generation of dual-channel ddr2-based motherboards. it has been tested extensively in multiple ddr2 motherboards to ensure compatibility and performance at its rated speed. this memory has been verified to operate at 800mhz at the low latencies of 4-4-4-12.
every part is tested in corsair's factory at 800mhz, but your actual results may vary depending on the overclocking margin of your cpu and motherboard. newer otherboards may be used for production test as they become available. corsair may periodically update the part with newer ram revisions of same or greater performance. ram used on the module may change without notice. © may 2007 corsair memory, inc.
previously sold for: £39.99+vat (£46.99 inc. vat) (saving you £11.75)
price: £29.99+vat (£35.24 inc vat)
buy now!
corsair 2gb ddr2 xms2 dominator pc2-8500c5 twinx (2x1gb)
the dominator series twin2x2048-8500c5d is a 2048 mbyte matched pair of ddr2 sdram dimms built using corsair’s latest high performance heat sink with dual-path heat xchange (dhx) technology. this part delivers outstanding performance in the latest generation of dual-channel ddr2-based motherboards. it has been tested extensively in multiple ddr2 motherboards to ensure compatibility and performance at its rated speed. this memory has been verified to operate at 1066mhz at latencies of 5-5-5-15. the twin2x2048-8500c5d comes with
enhanced performance profiles (epp), the open standard for performance module spd’s jointly developed by corsair and nvidia. epp spd’s on corsair modules allow users to automatically configure epp enabled motherboards with aggressive memory performance settings, for maximum memory and system performance. performance of these modules incorporating dhx can be further enhanced by using the optional dominator airflow fan, for even more cooling and protection.
previously sold for: £49.99+vat (£58.74 inc. vat) (saving you £18.80)
price: £33.99+vat (£39.94 inc vat)
buy now!
ocz 4gb (2x2gb) pc2-9200c5 1150mhz flex ii passive/watercooled dual channel ddr2 (ocz2fxt11504gk)
my-111-oc_400
the flex ii memory series is designed for blazing speeds demanded by enthusiasts. these premium modules run at incredibly fast ddr2-1150 speeds for high-performance systems with integrated water-cooling. designed to the very core to offer enthusiasts the thermal management innovation of hybrid water and passive cooling, the new pc2-9200 flex ii series offers rock-solid stability and performance for your high-end gaming or overclocking system. the ocz flex ii heat management solution enables high-frequency memory to operate within an optimal balance of extreme speeds and low latencies without the high temperatures that inhibit or damage the module. each pc2-9200 flex ii memory module features this breakthrough thermal management technology from ocz. combining an effective new heatspreader design with integrated liquid injection system and dedicated channels directly over the module’s ics, flex ii effectively dissipates heat produced by high-speed memory. this sophisticated series was engineered with a unique “flexible” design to give enthusiasts the option to run the modules passively or water cooled via the thick array of aluminum fins, and the concurrent use of both options promotes maximum heat dissipation. the pc2-9200 flex ii modules are optimized for the latest cutting edge platforms and will be available in high-capacity 4gb (2x2048mb) dual channel kits. in its continued effort to make overclocking a user-friendly pastime, ocz includes all the necessary accessories right in the box to setup your unique water-cooling system immediately after purchase, without the inconvenience of searching for additional hardware.
- 1150mhz ddr2
- epp 5-5-5-18 (cas-trcd-trp-tras)
- unbuffered
- ocz lifetime warranty
- 2.1 volts
- 240 pin dimm
- flex ii xlc heatsink*
- epp-ready
- 2.15v evp**
- 2 x 1/4" id (inner diameter) barbs
- 3/8" and 1/2" barb adaptors
- 4-way manifold barb
- 40" plastic tube
note: these modules use very wide heatsinks which means you can only fit one kit (two modules) into a motherboard for a total of 4gb of memory due to the width of the flex ii heatsinks.
previously sold for: £119.99+vat (£140.99 inc. vat) (saving you £41.13)
price: £84.99+vat (£99.86 inc vat)
buy now!
ocuk geforce 9800 gx2 1024mb gddr3 tv-out/dual dvi/hdmi (pci-express) - retail
beautifully designed and engineered for extreme power, the ocuk nvidia® geforce® 9800 gx2 1gb graphics card is the console within - a complete, high definition entertainment and gaming solution for the pc. with nvidia hybridpower™ technology and two on-board gpu's, the ocuk nvidia® geforce® 9800 gx2 is bar-none the fastest graphics card available and up to 50% faster than geforce® 8800 ultra. when paired with an additional ocuk nvidia® geforce® 9800 gx2-based graphics card and an nvidia nforce® 7 series motherboard, this quad nvidia sli® technology solution creates the most awe-inspiring, screaming fast gaming platform to date. be blown away by scorching frame rates, true-to-life extreme hd gaming, a picture-perfect hd dvd and blu-ray disc® movies with ultra-smooth playback.
- geforce 9800 gx2 core running at 600mhz
- shader clock speed of 1500mhz
- 1024mb gddr3 memory running at 2000mhz
- 512-bit memory interface
- 256 stream processors
- shader model 4.0
- texture fill rate: 76.8 billion/sec
- memory bandwidth: 128gb/s
- up to 50% faster than geforcer 8800 ultra
- display connectors: 2 dual-link dvi-i, hdmir out
- hdcp capable, hdmir capable
- designed for extreme hd gaming
- nvidia pure video technology
- dedicated video processors free the gpu shaders to run 3d applications
- dual dual-link dvi supports two 2560 x 1600 resolution displays
- hdcp enabled!!
- sli ready
- true high dynamic range rendering support – based on open exr technology
- world's first unified architecture supporting microsoft® directx® 10
- built for microsoft® windows® vista™
- 2yr warranty with ocuk
note: this card is 295mm in length so make sure it fits in your case! also the cards require pci-e x16 slots, they will not function in a x8 slot so for sli you need dual x16 mainboard. finally 600w minimum for psu and 700w+ is recommended. also make sure your psu has true 8 pin pci-express connector rather than a 6+2 pin connector.
previously sold for: £299.99+vat (£352.49 inc. vat) (saving you £23.50)
price: £279.99+vat (£328.99 inc vat)
buy now!
xfx geforce 8800 gtx extreme 768mb gddr3 hdtv/dual dvi (pci-express) - retail (pv-t80f-she9)
the 8800 series is the world's first directx 10 graphics card with full shader model 4.0 support. it delivers unparalleled levels of graphics realism and film-quality effects. even more, it also supports the nvidia lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. built for windows vista™, the 8800 series ensures the best possible performance when running the windows vista 3d graphical user interface. the 8800 series complies with many cutting-edge xtreme-hd features. it provides two dual-link dvi connections to support two hi-end, ultra-large, 30-inch lcd monitors at a mind bending 2560x1600 resolution. with an embedded revolutionary hdtv encoder, the 8800 series also supports crystal clear hdtv output up to 1080i. on top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as mpeg-2, wmv, wmv hd with nvidia exclusive purevideo™ hd technology. what's more, playback of hd dvd, blu-ray disc, and other protected content at full hd resolutions with integrated high-bandwidth digital content protection (hdcp) is fully supported. the winfast® px8800 series complies with many cutting-edge xtreme-hd features. it provides two dual-link dvi connections to support two hi-end, ultra-large, 30-inch lcd monitors at a mind bending 2560x1600 resolution. with an embedded revolutionary hdtv encoder, the 8800 series also supports crystal clear hdtv output up to 1080i. on top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as mpeg-2, wmv, wmv hd with nvidia exclusive purevideo™ hd technology. what's more, playback of hd dvd, blu-ray disc, and other protected content at full hd resolutions with integrated high-bandwidth digital content protection (hdcp) is fully supported.
- geforce 8800 gtx core running at 600mhz
- shader clock speed of 1350mhz
- 768mb gddr3 memory running at 1900mhz
- 384-bit memory interface
- 128 stream processors
- shader model 4.0
- texture fill rate: 36.8 billion/sec
- memory bandwidth: 86.4gb/s
- hdcp enabled!!
- sli ready – upto 2x the performance of a single gpu (available on with future driver release)
- supplied with company of heroes (dx10 version) full pc-game
- 2yr warranty with ocuk direct (for xfx warranty contact ocuk for rma and we will endeavour to resolve your problem within 7 working days)
note: this card is 275mm in length so make sure it fits in your case! also the cards require pci-e x16 slots, they will not function in a x8 slot so for sli you need dual x16 mainboard. finally 500w minimum for psu and 600w+ is recommended.
previously sold for: £164.99+vat (£193.86 inc. vat) (saving you £29.37)
price: £139.99+vat (£164.49 inc. vat)
buy now!
bfg geforce 9800 gtx 512mb gddr3 tv-out/dual dvi (pci-express) - retail
the bfg nvidia® geforce® 9800 gtx 512mb graphics card raises the performance bar by enabling full-throttle lifelike game play at intense resolutions while providing optimal power management with hybridpower™ technology. the purevideo® hd engine delivers unmatched video and movie quality with spectacular picture clarity featuring scene-optimized color and contrast enhancement. and when coupled with nforce® sli®-ready motherboards, provides amplified performance up to 2x in a dual sli configuration and up to 2.8x in 3-way sli* mode. packing more performance at an exceptional value, the bfg nvidia® geforce® 9800 gtx 512mb graphics card offers extreme hd gaming and a first-class entertainment experience.
- geforce 9800 gtx core running at 675mhz
- shader clock speed of 1688mhz
- 512mb gddr3 memory running at 2200mhz
- 256-bit memory interface
- shader model 4.0
- full-throttle gaming at extreme hd resolutions and support for 3-way nvidiar slir mode
- full microsoftr directxr 10, shader model 4.0 and pci expressr 2.0 support
- hdcp enabled!!
- free bfg t-shirt, teflon stick pads and stickers
- lifetime manufacturer warranty (contact bfg representative on 001 866 234 3499 for warranty services)
- 24/7 email manufacturer support (http://www.bfgtech.com/tech_redux.html)
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Previously sold for: £174.99+VAT (£205.61 Inc. VAT) (Saving you £11.75)
Price: £164.99+VAT (£193.86 inc VAT)
BUY NOW!
OcUK GeForce 8800 GTS 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
redefine your gaming reality with the ocuk geforce® 8800 gts 640mb pci express graphics card featuring the world's first directx® 10 gpu and a powerful unified architecture that delivers an incredibly true-to-life gaming experience. power through games at record speeds and charge through game maps with vividly realistic, sun-up to sun-down hdr lighting effects while steering clear of mind-blowing physics effects such as explosions, fire, and smoke. crank up 16x full-screen anti-aliasing without missing a beat - no jaggies, no worries. and when you're not destroying the enemy, relax watching your favorite movies with nvidia purevideo™ technology.
- geforce 8800 gts core running at 513mhz
- shader clock speed of 1200mhz
- 640mb gddr3 memory running at 1600mhz
- 320-bit memory interface
- 96 stream processors
- shader model 4.0
- texture fill rate: 24 billion/sec
- memory bandwidth: 64gb/s
- hdcp enabled!!
note: these cards require pci-e x16 slots, they will not function in a x8 slot so for sli you need dual x16 mainboard. finally 500w minimum for psu and 600w+ is recommended.
previously sold for: £149.99+vat (£176.24 inc. vat) (saving you £82.25)
price: £79.99+vat (£93.99 inc vat)
buy now!
ocuk geforce 8800 gts 320mb gddr3 hdtv/dual dvi (pci-express) - retail
redefine your gaming reality with the ocuk geforce® 8800 gts 320mb pci express graphics card featuring the world's first directx® 10 gpu and a powerful unified architecture that delivers an incredibly true-to-life gaming experience. power through games at record speeds and charge through game maps with vividly realistic, sun-up to sun-down hdr lighting effects while steering clear of mind-blowing physics effects such as explosions, fire, and smoke. crank up 16x full-screen anti-aliasing without missing a beat - no jaggies, no worries. and when you're not destroying the enemy, relax watching your favorite movies with nvidia purevideo™ technology.
- 320mb gddr3 memory running at 1600mhz
- shader model 4.0
- hdcp enabled!!
previously sold for: £114.99+vat (£135.11 inc. vat) (saving you £64.62)
price: £59.99+vat (£70.49 inc vat)
buy now!
bfg geforce 8800 gt oc 512mb gddr3 hdtv/dual dvi (pci-express) - retail
your search for the perfect graphics card is over. the ideal combination of power, performance, and price, the bfg nvidia® geforce® 8800 gt oc™ graphics card offers 112 stream processors, a 512mb 256-bit frame buffer, standard-setting geforce 8 series features and, a strikingly immersive directx 10 gaming experience. ultra-realistic smoke, rain, explosions, lighting, terrain deformation and motion blur enable jealousy-inducing, lightning-fast gameplay in the hottest games, including crysis, hellgate: london, call of duty 4, and gears of war. with full support for pci express 2.0 and featuring second generation nvidia purevideo™ hd engine, the sli™-ready bfg nvidia geforce 8800 gt oc graphics card was worth the wait.
- geforce 8800 gt core running at 625mhz
- shader clock speed of 1566mhz
- 512mb gddr3 memory running at 1800mhz
- 112 stream processors
- shader model 4.0
- memory bandwidth: 57.6gb/s
- hdcp enabled!!
Previously sold for: £119.99+VAT (£140.99 Inc. VAT) (Saving you £27.03)
Price: £96.99+VAT (£113.96 inc VAT)
BUY NOW!
Powerball Original 250Hz Blue
Designed to improve the wrist muscles, simply set the inner section spinning, rhythmic circular hand and wrist movements not only maintain the rotation, but also make it steadily faster. Increased in centrifugal forces make it harder to keep hold adding resistance to your wrist thus making you stronger.
Not only is this a great exercise for your wrist, it is also extremely addictive as it incorporates a high score system.
The perfect instrument to gently rehabilitate lower forearm and wrist joints affected by carpal tunnel syndrome, repetitive strain injury, arthritis & previous breakage.
Previously sold for: £7.99+VAT (£9.39 Inc. VAT) (Saving you £2.35)
Price: £5.99+VAT (£7.04 inc VAT)
BUY NOW!
Powerball Neon Blue Pro
Introducing Powerball - one of the most unique and dynamic products available on the web today - 8 world records and counting!
Powerball is a dynamic and completely revolutionary new gyroscope that literally explodes with mind numbing torque and inertia once you activate its internal rotor.
It's about the same size as a tennis ball and weighs just a little more, but take a Powerball in your hand, set that rotor in motion with the cord provided (or use your finger when you get used to it) and you'll experience an extraordinary sensation:
Power ball slowly comes alive with gyroscopic force - a sublime yet pleasant resistance to your movement which is transmitted directly into your wrist and arms and which provides soothing, non impact rehabilitation at these lower speeds.
You want more?
Take it higher...much higher!
Bring your new Powerball up...up to 10,000rpm...the forces are now much stronger, much more vibrant. Higher! Take it to 12,000rpm...no, higher still...take it right up, thrashing and jerking as your arm and wrist try to control and calm it down, faster and faster it spins until you have it up to an unbelievable 15,000rpm at which point it's exerting almost 40lbs of pressure on your limbs and is travelling at nearly 250 revolutions per second - no batteries, no motor, just pure gyroscopic power - the fastest human propelled device ever created!
- Unconditional Powerball Lifetime Warranty
- Includes LCD readout displaying RPM
- The highest quality Original Powerball Neon Blue
- Suitable for 14 years and older
Previously sold for: £14.99+VAT (£17.61 Inc. VAT) (Saving you £2.35)
Price: £12.99+VAT (£15.26 inc VAT)
BUY NOW!
Powerball Signature Pro Edition
Dynamic, exquisite, absolutely gorgeous! The extraordinary new Powerball Signature with its sapphire white light neon rotor revolving within a subtly smoked shell is truly a design classic and will exceed the very highest expectations of Powerball fans all over the world once they experience its silky smooth movement!
Put its rotor in motion and the ball instantly comes alive with Gyroscopic force - a sublime yet pleasant resistance to the movement of your wrist and hand and one which grows in its intensity as the speed of the rotor builds...faster and faster...up to a point where it is thrashing and jerking furiously, literally exploding with inertia and almost impossible to control!
This limited edition gyroscope has a top speed in excess of 16,000rpm and can generate over 40lbs of resistance on the hands and arms as it spins (which is quite extraordinary given that it is just the size of a tennis ball and weighs under 300grams!).
The new Signature is our premium Neon Powerball model and is supplied with an exclusive mini DVD providing you with exercise routines, three exciting Powerball film clips, starting tutorials plus the full suite of Akis World Speed records to really spin your mind!
An inbuilt computer on the outer shell offers you complete control over how fast (or slow!) to operate the ball and archives important data like the highest achieved speed (really important when challenging mates to a Powerball showdown...anywhere...anytime...Punk! :-)
Also included as standard are two starting cords and a safety wrist strap to help ensure many years of smooth operation with this superlative product.
Previously sold for: £19.99+VAT (£23.49 Inc. VAT) (Saving you £7.05)
Price: £13.99+VAT (£16.44 inc VAT)
BUY NOW!
Asus Rampage Formula Intel X48 (Socket 775) PCI-Express DDR2 Motherboard
Asus Republic of gamers brings you the new Intel X48 sensation that combines powerful performance with great energy efficiency! also comes with the world’s first ASUS EPU (Energy Processing Unit), allowing the CPU power supply to be digitally monitored and fine-tuned with improved VRM efficiency in heavy or light loadings – attaining the best possible power efficiency and energy savings to help save the environment. Catering to astute users who require the best performance for their games and overclocking alike, the Republic of Gamers, producer of gaming motherboards, has released the new Rampage Formula motherboard. With the innovative Pin-Fin Thermal Module, this cutting-edge motherboard provides quiet, efficient cooling that allows users to enjoy a more stable environment for overclocking. Additionally, the inclusion of the innovative overclocking technology - CPU Level Up, lets users obtain flexible CPU overclocking easily - even without prior overclocking knowledge.
- Pentium 4/Pentium D/PentiumEE/Core™2 Duo/Core™2 Quad/Core™2 EE/45nm CPU LGA775
- Intel X48 with ICH9R
- 1600/1333/1066/800 FSB
- 4 x DDR2 1200(O.C.)/1066/800/667
- 2 x PCIe 2.0 x16
- CrossFire X16+X16
- SATA 3Gb/s*6(RAID 0, 1, 5, 10)
- 2 x 1394a
- SupremeFX II Audio Card
- 2 x Gb Marvell PCIe
- Heatpipe Design
- Voltiminder LED,
- COP EX,
- CPU Level Up,
- Loadline Calibration,
- Extreme Tweaker,
- ASUS EPU,
- LCD Pster,
- Onboard Switch,
- Q-Connector,
- Green ASUS
Previously sold for: £179.99+VAT (£211.49 Inc. VAT) (Saving you £37.60)
Price: £147.99+VAT (£173.89 inc. VAT)
BUY NOW!
Lian-Li PC-B25B Aluminium Midi-Tower - Black
The Lian-Li PC-B25B Internal manufacture emphasises artistic and silent processing. It is the most perfect design case in current market. The PC-B25 has the largest capacity expansion case in classical silent series; its silence is deafening. The external surface has been through anodizing process, with black color and a Blue LED lighting design for the front panel.
- Dual layer design for the side panels, its exterior has the sense of fashion and technical taste for the blue lighting front panel.
- Both side open design, suitable for everyones need.
- Left, right side panel design with air inlet helps to exhaust the heat promptly
- 5.25¨ bay x 3
- 3.5¨ bay x 1
- 3.5¨ internal x 5
- Patent anti-vibration design for the internal HDD, can be turn 180 degree
- Removable M/B tray design, suitable for ATX mother board
- Cable management with clips design at the back of the M/B tray help to marshal the wires, prevents the cold air obstruct by the wires.
- Dual-layer designed for the side panels, with sound insulate wadding and stripe in the case makes it to be completely silent.
- Prevent hand cut design in the interior, makes it safer when installing.
Previously sold for: £139.99+VAT (£164.49 Inc. VAT) (Saving you £29.38)
Price: £114.99+VAT (£135.11 inc. VAT)
BUY NOW!
Razer Lycosa Gaming Keyboard (US Layout)
With an awesome host of features, the Razer Lycosa is on an unstoppable mission to destroy and dominate.
Execute complex combat maneuvers with swift dexterity. Launch your assaults timed to perfection. Annihilate your enemies and reign supreme on the battlefield. You now have the tactical advantage on every terrain, and your enemies’ fates are in your hands.
With its non-slip rubber finish, the Razer Lycosa offers optimum tactile comfort and makes slipping up in the heat of action a thing of the past
Backlight Illumination with WASD cluster lighting option
Make darkness your ally. While your enemies fiddle in the shadows, command precision and take hold of their fate with backlight illumination on the Razer Lycosa. With the right keys lit up, you can always be sure of your next move.
- Keytop with non-slip rubber finish
- Backlight illumination with WASD cluster lighting option
- Fully-programmable keys with macro capability
- Gaming cluster with anti-ghosting capability
- Slim keycap structure with Hyperesponse™ technology
- TouchPanel easy access media keys
- Gaming mode option for deactivation of the Windows key
- 10 customizable software profiles with on-the-fly switching
- 1000Hz Ultrapolling™ / 1ms response time
- Earphone-out and microphone-in jacks
- Detachable wrist rest
- One integrated USB extension port
Approximate size: 469mm (length) x 168mm (width) x 15mm (height) – without wrist rest. 469mm (length) x 221mm (width) x 15mm (height) – with wrist rest
Previously sold for: £48.99+VAT (£57.56 Inc. VAT) (Saving you £8.22)
Price: £41.99+VAT (£49.34 inc. VAT)
BUY NOW!
Creative GigaWorks G500 THX Certified 5.1 Speakers
The stylish speakers of the GigaWorks ProGamer G500 complement the awesome sonic accuracy of this gaming speaker system. A THX Certified 5.1 system rated at 310 Watts total RMS power, along with its combination of raw muscle and technical sophistication, this system will blow you away. The performance-tuned ProGaming subwoofer dwarfs the competition. It combines a huge 8" front-firing long-throw woofer for chest-thumping low end frequencies. The Twin Flared DynaPorts™ maximizes airflow for cleaner, bigger, and more evenly dispersed bass. And there's an auxiliary input on the back of the sub to easily connect an MP3 player. Each performance-tuned ProGaming satellite speaker has a 3" full-range driver and a Flared DynaPort™ for extended lower-midrange sound. It also combines a keyhole wall mount, speaker wire spring clips and connector for use with speaker stands and wall mount hardware.
- Power: 310 watts total RMS power
- Front : 36 watts RMS per speaker
- Rear : 36 watts RMS per speaker
- Center : 36 watts RMS
- Subwoofer : 130 watts RMS
- 620 watts total Peak Power
- Overall Frequency Response: 35Hz to 20kHz
- Signal-to-Noise Ratio (SNR): 85dB
!!<<b>Note</b>>!! - This is a Creative Retail product with 2 years warranty and free Creative Technical Support.
Previously sold for: £129.99+VAT (£152.74 Inc. VAT) (Saving you £17.63)
BUY NOW!
Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache - OEM (ST3500320AS)
By combining proven components and state-of-the-art technology, the Seagate Barracuda 7200.11 family delivers up to 1TB of storage. Designed with Seagate’s 2nd generation perpendicular recording, the capacity, reliability and performance of this drive ensure the longevity of digital content for years to come.
- Capacity: 500GB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 5 Years
Previously sold for: £54.99+VAT (£64.61 Inc. VAT) (Saving you £5.87)
Price: £49.99+VAT (£58.74 inc. VAT)
BUY NOW!
Seagate Barracuda 7200.11 1TB SATA-II 32MB Cache - Retail (ST310005N1D1AS-RK)
- Capacity: 1TB
- Cache: 32MB
- Seek Time: 8.5ms
- Warranty: 5 Years
- Includes: Software, Manual, SATA Cable, Installation Guide, SATA Power Adapter & Mounting screws
Previously sold for: £124.99+VAT (£146.86 Inc. VAT) (Saving you £16.45)
Price: £110.99+VAT (£130.41 inc. VAT)
BUY NOW!
Samsung Bordeaux PS42Q97HDX 42" HD Ready Freeview Plasma TV
Introducing the Q97 Plasma which replaces the award winning Q7 range of 2006. The Samsung PS42Q97HD has a 13-bit processing capacity that can display an amazing 549 Billion colours, while its high brightness ensures clarity, and the 15,000:1 contrast ratio adds every last detail. Real Motion Studio Technology makes the picture on the Q97 Plasma natural end eliminates any motion judder for a smooth, clear image.
- Screen Size: 42"
- HD Ready (480i, 480p, 576i, 576p, 720p & 1080i Supported) (Sky HD, Virgin V+, Xbox 360 & Playstation 3 Ready)
- Resolution: 1024 x 768
- Contrast Ratio: 15000:1
- Brightness: 1500 cd/m²
- Colours: 16.7 Million
- DVB-T Digital Freeview Tuner
- Analogue Tuner
- 3x HDMI
- 1x Component
- 2x SCART
- 1x Composite
- 1x S-Video
- 1x PC VGA
- 2 x 10w Speaker System
- Dimensions: 1055mm x 759mm x 316mm (With Stand)
- 1 Year Warranty
Previously sold for: £499.99+VAT (£587.49 Inc. VAT) (Saving you £41.13)
Price: £464.99+VAT (£546.36 inc VAT)
BUY NOW!
Samsung Series 5 LE40A559P4F 40" True HD Freeview LCD TV
For the ultimate viewing experience this year Samsung introduces the Series 5 LCD range. The Series 5 with its resolution of 1920x1080 ensures you will be watching the very best pictures possible when viewing Blu-ray or playing 1080p gaming machines. The Series 5 also has 3 HDMI sockets, 1 placed on the side of the panel for ease of use. The Series 5 range is packed with features to ensure outstanding picture quality, Super Clear Panel, Movie Plus, Wide Colour Enhancer and Game Mode are just some of the features that ensures the Series 5 range offers the ultimate viewing experience.
- Screen Size: 40"
- True HD (480i, 480p, 576i, 576p, 720p, 1080i & 1080p Supported) (Sky HD, Virgin V+, Xbox 360 & Playstation 3 Ready)
- Resolution: 1920 x 1080
- Contrast Ratio: 30000:1
- Digital Tuner
- Analogue Tuner
- 3x HDMI
- 1x Component
- 1x S-Video
- 1x Composite
- 2x SCART
- 1x PC VGA
- Dimensions: 997mm x 686mm x 300mm (With Stand)
- 1 Year Warranty
Previously sold for: £729.99+VAT (£857.74 Inc. VAT) (Saving you £35.25)
Price: £699.99+VAT (£822.49 inc VAT)
BUY NOW!
Click here to see listing of all This Weekends Special Deals!!
Click here to see listing of all This Week ONLY Deals!!
Ordered the samsung 24". Hoping ive made a good choice (Going from a 19" Viewsonic).
My huge worry, and one which has kept me ordering from OCUK for a while is my boycott of Citylink. Never had a good experience, but we shall see.
