ambient temperature effect on component temp
17 Jul 2008
if you allow the ambient temperature to increase by say 10 degrees would the component temperature increase be the same, or would it simply mean things get warmer but not be 10degrees?
From my understanding of it, you'd struggle to get any component to a lower temp than your ambient temp, so depending on your current temps and the cooling you've got, you may not see a big increase.
