- 8 Jan 2011
- London, UK
I often read threads where people will quote their ‘idle’ temps. This will be in the context of any sort of setup: air cooled, AIO coolers, full on custom water builds of various size and complexity.
So I guess the ‘success’ of any given idle temperature is down to what the ambient room temperature is actually at.
And therefore it’s logical to conclude that the reporting of a good idle temp has a lot to do with the delta between the Ambient and Idle temps.
I’m running a 12900k at stock, on a three radiator watercooled system. I’m getting an idle of about 28-29 when ambient is at around 24-25. So a delta of 3-4 degrees depending.
From memory of the only other system I’ve owned (4790k also watercooled) I recall this one had a delta of around 2-3.
So I’m trying to figure out A) if my loop isn’t so good this time round (acknowledging I am trying out a more ‘silent’ config with the fans and pump) , B) whether my application of paste to CPU isn’t so good, or C) whether this chip just runs hotter than other CPUs - as I have read in numerous places.
So what’s the accepted theory and how should one approach this ‘analysis’? Cheers guys
