AMD 1055T Voltage
30 Nov 2010
Caerphilly
What is the safest voltage you can use for the 1055T and still have it's lifespan to maybe 2 years +
Even though it runs at around stock voltage of 1.37 and when the turbo core mode kicks in, it shoots up to 1.47V
1.375 was stock for mine but the cpu doesnt need anywhere near that :S
i just run mine stock and i down volted to 1.250 ^_^ no problems even at 100% load on all cores :O (much cooler aswell)
you might not even need as high a voltage as you would think when OC'ing so i would play around with it
My phenom ii runs at 1.55v.
CPUID says 38c idle and ive never seen it run above 50 with stock cooler.
Sounds like AMD doesn't want us to know the real safe voltages for the 1055T lol
1.5V does sounds reasonably safe if turbo mode is going to run at 1.47.
Once I get my replacement cpu and motherboard back, I will see what sort of overclock I could possibly achieve again. I couldn't keep it stable last time at 4.0GHz
