AMD 3700x Handbrake X265 2160p/60 Encode Hitting 99% CPU Utilisation
9 Jul 2007
After a few seconds then terminating the encode when trying to convert 80Gb MKV over LAN
Should this be happening and if so is there a setting to ramp back the %CPU used??
Encoding will always use as much CPU power as is available unless there is some feature in the application to limit this or you use a third party utility if even one exists.
Also look at the size of the file your are talking about 80Gb.
So yes sounds completely normal.
