Hi All,
Just built a small HTPC with a Gigabyte GA-MA78GPM-DS2H and a AMD 4850e.
The temp as reported by the bios is running at 36c while it idles, is that right?? My E6400 over clocked to 3.2 runs at 19c idle.....yes i has a freezer pro 7 in an antec 900, but the 4850e is a 45w cpu that is supose to run cool.
Running stock cooling so also if someone could recomend me a low profile cooler.........i have just over 8 cm from top of the chip to case.
Also after a 80mm by 15mm pwm case fan.......can only fine 25mm ones. Is there such a thing.
Many thanks in advance.
Mc6701
Mc6701
