Hello!
Facing issues with my new AMD Ryzen 5600x build
Config:
AMD Ryzen 5600x
Gigabyte b550 aorus elite
Nvidia Inno3d 3070 x3 ichill
Nzxt x53 AIO cooler
Crucial Ballistix 16gb 3600hz
PSU: Seasonic Focus GX-750 750W 80+ Gold Modular
It crashes only while gaming and it is very random i.e. within couple of minutes or after 3-4 hours of gaming. Most of the time it happens only once but somedays 3-4 times in 30 minutes. The screen goes black and does a quick restart, lights and fans in the CPU keep running though. I did all the possible tests for memory, psu, gpu i.e. Prime95 + Furmark, 3d mark, memtest 86 etc. but doesnt crash during that time. Tweaked XMP settings as well but still the same issue.
I did check the temperature and they seem to be okay i.e. while valorant it around 55-60 and warzone, gta around 70.
I dont have the luxury to swap the GPU and see what parts are failing. I did try to change the CPU i.e. 5600x with another 5600x and still the same result.
Any suggestions?
Thanks!
Config:
AMD Ryzen 5600x
Nzxt x53 AIO cooler
Any suggestions?
Thanks!
