- 2 Dec 2004
- Essex
Hi Everyone,
I am building my first PC for 12 years. Wow a lot to learn! Technology has definitely moved on! I am getting an AMD7700X, Asus TUF 670E plus Wifi and a Lian Li Galahad 360 AIO watercooler. So, from my research it seems that the 7700X targets 95 degrees as a constant temperature. This seems to mean that the pump will go up at that temp and the fans will as well making it quite loud. I have also learned that this will mean that the CPU will draw more power to attain the 95 degree target, which is essentially a waste as there is no additional performance. These chips have been out a while and I know many of you will have them. So, I'm after some advice from you experts. How do you deal with this? Do you amend fan and pump profiles? Thanks for any help.
Cheers,
Blue
Cheers,
Blue
