AMD 7750 boost.
23 Feb 2010
Hi, ATM running my 7750 (wanting to get it too max before buying new!)
232 # 15 + 1.0 volts. @3480..... 29: temp , after 6-7 hours heavy use.
What sort of volts do these cpu's get to (max).
Thx.
your volts are wrong to start with 1.0v????
what is your vcore at?
at 3.4ghz is prob the best your gunna get from a phenom 1
LOL, i woke up thinking i should have added a dot (.) 100v in my post!
So its on 1.39v (3.48) ain't to bad i think. Oh it does go higher! But was asking what Is safe for these chips? Seen 1.7v? Should i see that as the limit?
Thx.:D
Thx, atm i get 29 temp (cpu) , running what i do.
Case never over 32. Gpu maxed out , never over ( tho old now, lol.) 34.
This cpu used to get too , 49 (temp) max on its std cooler after a long night.
So i know i can push this a little further knowing what my safe max temp is,
1.5v Is good but what have these chips got to?:D
Thx a lot for that, hmmm, Very tempted! Will look into it abit more!
All that screeney looked same as my cpu, Will give it thought!:D
No, i think its never gonna happen.
So my aim is 3.6-3.7 tops i think. (fingers crossed).
If it blows some-at at around 3.59 then its had a good run.;)
