Permabanned
- 7 Aug 2017
- by the tower the one up north ..
thinking on getting the Sapphire Radeon RX 7900 XT Nitro but what block would fit it ? can only find one def answer Bykski ??
When I used the alphacool GPU config, it recommends the "Alphacool Eisblock Aurora Acryl RX 7900XTX/XT Nitro with Backplate" - Is that the one you have for the Pulse?Yeah Alphacool make make a block. I've got it to go on my Pulse which I'll be doing at some point this week. You can check with the GPU config on their site https://www.alphacool.com/en/gpu-config
Also obviously entirely your choice but if your just going to put a block on the card I would get the Pulse over the Nitro, no point paying extra for the Nitro cooler when its no going to be use. The Nitro does have a 3 PCI-E power connectors but I don't think they make much difference with the XT. My Pulse boosts to ~2800mhz when undervolted to 1050mV with power limit left at 0% with stock cooler.
Excellent, thanks. I've just ordered the Pulse from OCUKYeah. The Pulse and the Nitro both use the same PCB. The Nitro just has a few extra components for the RGB and extra power. Both are the same layout so if the blocks fits the Nitro it will fit the Pulse![]()
Just for piece of mind:Excellent, thanks. I've just ordered the Pulse from OCUK![]()
Brilliant, thanks. This will be my first time fitting a GPU waterblock, so good to get the confirmationJust for piece of mind:
XT Pulse PCB
Nitro XTX PCB
As you can see both the same but Pulse is just missing a few compoments
Not that it needs confirming anymore but just to confirm further. I fitted the Alphacool block to my Pulse XT last night. Fits perfectlyBrilliant, thanks. This will be my first time fitting a GPU waterblock, so good to get the confirmation
Cool. Mine is ordered, think it’ll be a couple of weeks till it arrives.Not that it needs confirming anymore but just to confirm further. I fitted the Alphacool block to my Pulse XT last night. Fits perfectly![]()
How was the fitting process? Does it come with everything?
Great thanks. It’s an expensive bit of kit to f up!Fitting was pretty straightforward and the block comes with everything you need. Instructions are easy to follow![]()
Nice!
Block weighs ~2kg!
