Hi there, Just purchased a Asus DC2 TOP 7970 and the voltage appears to be locked at 1.178
There was a review posted in september showing the voltage going to 1.4v in GPU tweak, I've just tried quite a lot of different versions of GPU-Tweak, none will go above 1.178.
Could you tell me which cards are not voltage locked? Had stability issue's with the lightning BE which is unlocked. Any other cards?
Cheers.
Edit: nvm, decided to return the card, Purchased a Sapphire Vapor X 7970 which does have voltage control.
There was a review posted in september showing the voltage going to 1.4v in GPU tweak, I've just tried quite a lot of different versions of GPU-Tweak, none will go above 1.178.Could you tell me which cards are not voltage locked? Had stability issue's with the lightning BE which is unlocked. Any other cards?
Cheers.
