Hi guys,
My new amd 7990 has been reaching temps of 91c under load after a few hours of playing. Is this too hot and will ot damage my card, I've ordered some more side pamel fans.
Thanks
Whats a good temp under load for this card
Ok thanks I hope the fans do the job? Should I increase the cards fan speed?
Hi guys,
Thanks
Good thing you have the mech panel, as Corsair lines of Windowed panel cases whilst look good, all of them are relatively poor performance for GPU cooling.My old card gtx 590 was fine in my case which is corsair 600t. I've bought the mesh side panel and 2 large fans so hopefully that will help!
How do I disable ulps
Na, what I mean is you should mount the fans on the side-panel as exhaust (getting the hot-air out of the case), not intaking.When you say exhaust fans, is there a particular type for this?
No the other way round.So when I mount the fans, I obviously have them pointed so they blow cold air into the case
