AMD 8350 + Sabertooth 990FX R2.0 problem
27 Oct 2007
Earlier today I was playing around with a overclock. Nothing major, just 4.4GHz. This was happily configured to run at 1.37v(ish) and it was stable. I thought it was a little high so I decided to see if I could get any lower. At this point, I decided to update my BIOs to the latest in case they gave any positive effects to my overclock. I updated to the latest with no problem. I then set the LLC to high and managed to get the required voltage down a little more - around 1.35v stable. All was good but I decided to see what the stock voltage was again.
I removed the overclock and booted into Windows and saw the voltage in CPUz - it was about 1.27v under load. I thought it was a bit odd, it never was that low before I updated the BIOs! It was normally above 1.3v at least. I ran some stress tests and it appeared stable (for the 20 minutes I tested) however, in CPUz it kept clocking to 3.4GHz every few seconds and back to the stock 4GHz. Turbo was on, but I did not see the CPU clock up to 4.2GHz. This was odd as it never normally did that and the temperatures are fine (60C VRM and 50C CPU).
At this point I decided to overclock to 4.2GHz on stock voltage as I could do this normally on my old BIOs. It then failed when I ran Prime95 in under 5 minutes. It worked before I updated the BIOs :( I then tried 4.4GHz and used the exact same settings as I did before (I wrote them down) and a few cores failed.
I then downgraded my BIOs to the one I had in the first place (Version 1302) but the problem persists! I can't do 4.2GHz on stock voltage even though I was able to before.
I have further tried the following to resolve the problem:
Clearing cmos
Several times to reset the BIOs to defaults
TL;DR: Was overclocking fine, updated BIOs, CPU ran at a much lower voltage than normal, was stable at this voltage, tried 4.2GHz on the new BIOs which was fine before I updated, 2 cores crashed. Downgraded my BIOs to the version I was okay with, tried 4.2GHz again on stock but still crashed. Tried 4.4GHz with same settings as before, 3 cores crashed.
I'm not sure what the issue is as my computer has the same software and BIOs as it was before (and settings). Any help is greatly appreciated, thanks :)
Was the voltage beforehand set to automatic? Might be why the voltage was higher before?
AMD cool n quiet might be messing you around if it's on?
Yeah it was set to 'Auto' before and after the BIO updates. It seems odd how it can't be stable at 4.2GHz for 5 minutes with stock voltages, even though the CPU can turbo up to that.
AMD cool and quiet is also on but it's configured the same as it was before. I also tried the overclocks with it off but it did not make any difference (apart from stop clocking to 3.4GHz).
Is everything on Auto except for the vcore and LLC? Are you overclocking on the busclock?
You will need to check all the settings to ensure that optimal defaults selected are suitable.
You may be better setting out with a slightly higher voltage. I use an offset of +0.06V at 4.6GHz (approx 1.39V under load).
At the moment everything is on auto apart from the multiplier which is set to 21 to get to 4.2GHz. I just hit the defaults button in the BIOs and upped the multiplyer to get to 4.2GHz, which I have done before and have been stable for a while but not now even though I'm on the same BIOs version. :( Prime stops on 2-3 cores after 5 minutes.
Auto regulates the v-core as and when it needs it, so that's why it was stable before, it was drawing more than 1.27v.
Get everything configured manually,
I was thinking about doing everything manually but I was concerned a bit as to why it was "playing up" and acting differently even though I had the same settings before updating the BIOs. When it's on 4.2GHz the voltage is still on auto so it should slightly increase the voltage to get to 4.2 stable rather than cores failing on prime? I am slightly confused sadly :( I knew I shouldnt fiddle with updating the BIOs :P
