Upgraded from an AMD 6000+ @ 3.1 GHZ...blown away by the speed. The supplied HSF was surprisingly good ...ok I've got good airflow...but it's currently OC'd to 3.6 Ghz at stock volts on the included fan ..
so he's overclocked using the standard AMD fan, the same as mine, that's interesting...
but i doubt it'll be any good close to 4.0 ....unless you lap it, because mine was pretty rough....i also read yesterday that this style of fan runs 4 degrees cooler with the case side off, like mine.
the standard cooler might work better with a larger fan too..... just food for thought
i'm after the Prolimatech Megahalems Performance CPU.......... i think!
