AMD 955BE at 3.6GHz. Temps of 58-62c using intelburn?
21 May 2010
Just bumped my multiplier up to 18x to get 3.6GHz on my 955 BE C2 at 1.36v and ran intelburn set on 20 runs to test it. It passed but the temps were in the 60 region while doing so. It even briefly touched on 63c at certain points before dropping back down. just wondering if you think it would be fine for general usage and gaming seeing as itll never realistically reach those temps doing either of those? Im using an aftermarket cooler but its not the best. its a thermaltake minityp 90
Thanks
those temps are fine for the OC you have. You later on might want to get another cooler to knock temps down further like the H5O cooler for example.
