I have 2 programs that say the temp of my CPU
Asus probe tells me its sat at 29C on idle while AMD OverDrive tells me that all four cores are at 22C. Which should I believe?
You should trust CoreTemp.
Cores are hottest parts of CPU and should be always clearly above room temperature so values being practically same as it means they lie.Asus probe tells me its sat at 29C on idle while AMD OverDrive tells me that all four cores are at 22C. Which should I believe?
CPU value is temperature from physical CPU package and farther from heat source hence it's always clearly lower than actual core temperatures but at least that's entirely real looking value.
Dear Gareth,
Correct, as long as you are within the voltage and temperature guidelines you are ok. The temperature that should be monitored is the overall CPU temperature, not the core temp.
Best regards,
Jesse
AMD Global Customer Care
It's physical impossibility for heat producing part to be cooler than casing.wrong mate.
look above, my core temps are lower then the cpu temp, many many other am3 systems are the same..
also this is what amd emailed me about the temperature
wrong mate.
im not wrong.You're actually the one that is wrong. The reason that AMD have told you to look at the cpu temp as opposed to the core temp is because it's a well known fact that the phenom 2 core temp sensors lie.
maybe thats yours.My phenom 2 - if I'm to believe the core temp - is actually below room temperature, which is physically not possible for air cooling.
im not wrong.
amd says the overall CPU temperature is the most important one not the core temp, for all they chips, not just phenoms II.
many many years ago when i had a Athlon cpu they said the same thing that the overall CPU temperature is the most important one
what is your problem?Yawn. Did you by any chance go and learn about thermodynamics in the last ten minutes? Nope, I didn't think so.
I don't have one. Just pointing out the fact that you are, indeed wrong.what is your problem?
wrong mate.
??just back off..
Yip, but you're running a phenom 2... and from the above, you quite clearly believed that your core temps were below the cpu case temp.i'm just saying the overall CPU temperature is the most important one not the core temp, that goes for all amd chips, not just phenoms II.
see above.i don't really care if the core sensor lies, has thats not the important one.
end of...
u can usely work out the real core temp. on my 940 the core temp was about 11 - 13c over the tcare temp.If you had an acurate core temp reading, that would be a far more important reading than the CPU case temp reading, as the case isn't generating the heat...
