"AMD A10 Lightning V2X"
Yes... and no. Games which aren't demanding, such as Counter Strike: Global Offensive will run fine all maxed. Games like Far Cry 3 will struggle in anything but medium/low
Check out some videos of this setup on YouTube for clarification
Noway in hell would i pay 600 quid for that lol!
for a cpu bundle and card its like 500 with a 660/7850 and then alls you need is psu and case for 100, easy done really.
If you can build, get something like this and then upgrade to a used i5 2500K (or update the BIOS if needed and get a used 3570K) when you can. :)
YOUR BASKET
1 x **B Grade** Asus HD 7870 DirectCU II V2 2048MB GDDR5 PCI-Express Graphics Card w/ FARCRY3 & Sleeping Dogs PC Games £129.98
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £79.99
1 x Plextor M5S 128GB Solid State Drive - (PX-128M5S) £74.99
1 x **B Grade** Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £69.95
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £53.99
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £49.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £49.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £45.95
1 x BitFenix Merc Beta Gaming Case - Black £32.99
Total : £601.92 (includes shipping : £11.75).
OS included and everything. A total steal, and it will utterly demolish the system you linked for anything.
Thanks guys, I had suspected this much..
I can't build, so I was thinking of getting a premade system, or using the configurator.. but I guess I should make a new thread about that.
If you buy a CPU bundle it comes built and OCed, alls you will have to do is screw it up inside the case and plug the psu into it, its really simple.
Then the card slides into the pcie slot, connect that to the PSU.
Connect the card to the monitor and your good to go!
I think everyone knows how to swap HDDs :) girls can even do this :P
The integrated APU/hybrid crossfire combo is quite underrated for it's performance. In reality it can bat above it's league in comparison to some other discreet GPU solutions.
Well I probably could build one if I read/watched a tutorial, but I'm kind of busy lately, so was going for the convenience. Although I'm probably just being lazy!
Do you need to put the fans in too? Or are they already contained within the case and it's just a case of connecting them?
Also, would there be a substantial difference in cost if I built it myself? And even with the current offer of having it built/overclocked for free using the configurator?
the configurator offer is excellent but it runs out tomorrow so be quick!
A pre-built normally costs more as we have to build/test/warranty your system.
Building yourself isn't too hard but you get peace of mind with a pre-build.
Dependant on the case really, some cases have quite a few fans whereas other will usually just have one (exhaust fan).
