AMD A6 6400 Cooler onto A8 5600
6 Feb 2016
Hello
I have a A6 chip in my PC at the moment and got an A8 recently but without a cooler would the one from my a6 be alright to use or would it be smaller and overheat it? I did want a watercooler but i have very limited space as its an M-atx case and have a full size GPU in it
Thanks in advance
Gary
Nearly all AMD stock coolers tend to be the same regardless of the Chip. It may run a little warmer but not enough to cook it. All I would do is make sure there is sufficient positive airflow in your case.
Ah thats great... I have good cooling fan wise already i just thought going from dual core to quad could cause a problem
Thanks for the reply
