- 24 Mar 2005
- KENT
anyone know if AMD will stick with the atx design for there new socket am2
Jokester said:The BTX layout helps with case cooling and by extension cooling other components. It was Intel's response to the hotter P4 cores and their urge to get more out of them. Since then, they've went back to the P3 type of core and redesigns of that which run cooler so BTX has pretty much died a death.
Jokester
you have a BTX board?welshtom said:I use my stacker in BTX form. Lot easier to cool i found.
Tom
Overlag said:you have a BTX board?
im sure you mean you are running your ATX board upsidedown
ATX upside down doesnt mean BTXwelshtom said:well yes, as i said.
im running my STACKER in btx form.
Tom
so you have a BTX motherboard then?welshtom said:Well as i said
THE STACKER IS IN BTX FORM
whats so non understandable about that????
Tom
