- 10 Apr 2004
Basically, I need the cheapest/best cooler which makes the *least* noise.
The chip won't be overclocked and in fact will be under-volted/under-clocked.
It will spend 99% of it's life idle as it's going in an UnRAID server.
3-pin header is a must, as I will set the BIOS to turn the fan off at under 50C.
Thoughts?
Edit: http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-AR&groupid=701&catid=57&subcat=1395
Arctic Freezer Pro 7 Rev 2.
Rings some bells from my overclocking days and it has a 3-pin header.
Good choice?
Cheers
Thoughts?
Good choice?
Cheers
