AMD AM4 Wraith Prism Cooler Not Bad.
18 Oct 2002
Playing Doom in the man cave, the ambient temp was 28c.
65 c was the max I hit on the CPU so very pleased with the standard cooler.
Ryzen 7 3700x GPU 2080.
Case fans, 3 in, one out plus the psu out.
Can't say the same for my poor 3600 & it's stealth :/.
was hitting 97c on cod warzone...
ordered a 34 eSports, hopefully things change..lol
my 3600 & it's stealth hitting 75/78/90c in dirt rally 2 so bought a Scythe FUMA 2 120mm CPU Cooler, hope this is better temps
the wraith prism cooler for my 3900x was barley able to run my chip at stock speed, pbo didn't work properly as when my 3900x boosted to around 4.1ghz all core temps quickly spiked up over 80 degrees and past 85 my chip throttled back to around 3.4ghz, decided to move to custom watercooling on a 360mm radiator and saw huge improvements down in the mid 50's so cranked up the overclock to 4.4ghz all core and temps around 70 under load and gaming which is perfect.
Consider me jealous, always feared the idea of using water in my system, would consider an AIO at some point down the road :)
