AMD APU build basic PC check? £300-£350
14 Jun 2010
Trying to keep cheap as possible any idea if this motherboard will let me overlock the ram and apu well incase i wanted to do some light gaming?
Also which case should i get and can i get better PSU for around 50-60?
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor - £86.34
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard - £59.99
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory - £56.59
Storage: Western Digital - Green 240 GB 2.5" Solid State Drive - £29.98
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply -£49.99
Total: £282.89
Push 2400g Personally as if you every add in GPU, 4 core 8 thread cpu will perform better then the 2200g 4c/4t will !
PSU unit is Tier 3 , push tier 2 units if you can or have the space for it
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
^^^^still not fully updated though but covers your PSU choice
nice case for it
https://www.overclockers.co.uk/cool...0l-micro-atx-case-black-window-ca-36v-cm.html
Thanks for the reply Is 450W enough if i do overclock the CPU?
Ow man I almost said **** it lets build a real rig! I suck at budget build never turns out to be budget build. This PSU any good? I always used to buy EVGA Gold in the past..
https://www.overclockers.co.uk/be-q...us-silver-modular-power-supply-ca-11u-bq.html
cracking deal! normally quote Formula 450w as its the same price range, but with the bequiet being on price drop and simi modular ( formula isn;t) its a good buy
will allow you to open up and run 6/8 core ryzne and RX 580 or like wise GPU in the future too :D
Cheers all order never built a PC for £350 before
Great deal ...
You could take risk with GPU and get ryzen 1400 ....
Any way to test GPU ?
Yea I will try put test it on my brothers beast of a pc but he's bit territorial about his computer. I assume it will much better than the apu.
I love the way this started off as home pc build now I'm thinking about upgrading already lol
