Happy New Year all.
I require some assistance with a spec for an AMD build. My budget is flexible but I am trying to restrict myself to £2000 to cover the base unit inc W10 and OCUK build cost. I already have a keyboard and mouse and 2x24" dual Asus monitors for now. My intentions are to purchase a 34" Ultra Wide curved in the near future. I have also already acquired a Sabrent Rocket nvme of the rainforest that i would like to install later.
My uses for the system will primarily be used for work (MS office packages, Web browsing, Stock Trading, Youtube (Watching, Encoding Dash Cam footage to a new channel, Streaming and gaming) but not all necessarily at the same time.
I would also like the PC to be slightly flashy and make use of RGB. I don't plan to overclock at all and want it to be somewhat future proofed component wise. (e.g. 32GB instead of 16GB whilst prices are low, Adequate PSU).
I appreciate it maybe overkill but as noted don't plan to update it anytime soon. The PC would be in some instance left running 24/7 so it needs to be Cool (temp wise), Quiet and Efficient.
So far i have decided on the following but have no idea if they are the best fit or compatible.
Be Quiet DarkBase 700 RGB case
Gigabyte X570 Auros Ultra Motherboard
Ryzen 7 3700X CPU (plan to replace this in future to a 3950 or better once prices reduce)
32 GB Ram RGB Variant
2070 Super or RX5700
2TB nvme M.2 (i also have the Sabrent Rocket)
4TB SSD (For games and Work)
4TB HDD (For photos etc)
PSU 750W
A RGB Cooler and adequate RGB fans
I plan to submit the potential build to OCUK late February. Is there anything i should be mindful off release wise that might affect a possible build. I say this because i was originally going to purchase a Germanium pre build but was advised to wait for the new AMDs and this seems to have paid off.
Thanks all for your time.
PSU 750W
