When GPU mining stops becoming so popular, do you think that will create a flood of AMD GPUs on the market and then reduced prices?
Or is it more likely that the mining craze will be around for the forseable future?
Lord_ZED;25880344[B said:]I would not buy second hand AMD card nowadays. Image they been running 24/7 100% load for weeks.[/B]
Lifespan of those will probobly be down to 30% by teime You buy one lolz
Never had a issue buying second hand cards upto now but with mining i personally wouldn't buy a second hand AMD card anymore as you just dont know
So you're not interested in this old 4870 I got knocking around somewhere, then?![]()
a well set up mining rig gpu th shouldn't really be any worse than a gaming gpu theres cowboys on both sides who dont look after there cards thou and i'd assume with more miners there more chances for cards to be abused simply from the percentage wise
