by turning it off does that damage the CPU?
What sort of temps should I be seeing on the CPU;
my idle is 29c, but not sure how to generate a load temp?
did you have a good look around the bio, usually in the advanced option or cpu options, generally set to auto and have the choice of x1 - x5??
you said you were using the abit 3rd eye board right? im o/cin a friends pc tomorrow i think and he has the same board so if i find it i'll let you know where the option is if you havnt got it by then
It only works when you have the power setting in windows set to minimal, ie right click desktop then select properties, select screensaver tab and press the power button at the bottom and set power scheme to minimal power management.
cool and quiet works by slowing the cpu speed so that when it runs hot it will slow it down so that it will run at a lower temp, if u have a fan that is speed variable with the temp of the cpu then it should run 'quiet'.
So disable it as it is just slowing down ure cpu if anything.
Worse than that I believe it messes with the vcore (on the Abit AV8 at least) so if your overclock requires raised vcore it really isn't a good idea.
Additionally, C&Q is behind some of the synch/timestamp problems affecting dual core systems. The /usepmtimer boot option added by the cpu driver fixes this in many cases, but some peeps need the MS hotfix as well.
Hmm I dunno seems like a handy thing (for a non-overclocked rig),
I enabled Cool n Quiet in BIOS, set the HTT-Divider to auto, set the vCore to auto and the CPU-Multi to auto, installed the WinXP driver, and set power-management to minimal
Didn't play with the fan setting yet, the one that should slow down or shut-off the CPU fan. .
