- 16 Feb 2015
Hello all,
(I put this post here as I want people with this CPU to hopefully see this and give me some advice)
This thread might be a little long but I hope to explain myself clearly enough.
So I recently purchased this CPU:
https://www.overclockers.co.uk/showproduct.php?prodid=CP-360-AM&tool=3
I purchased this motherboard with it:
https://www.overclockers.co.uk/showproduct.php?prodid=MB-560-AS
So the first mistake I made was purchasing a motherboard that doesn't support - TDP: 220W. The one I purchased supports 140W TDP I believe?
So now my next question is, how the hell do I tell what the TDP limit is on a motherboard? Would it be this? (see below picture), if so then I don't know what motherboard would be suitable....
I have been told that this following board would be suitable
http://www.overclockers.co.uk/showproduct.php?prodid=MB-576-AS&tool=3
However it says 'supports CPU up to 140w'. If that is the TDP then this would be incorrect and people are feeding me incorrect information.
So basically I am getting frustrated with it all, I do not want to make the same mistake twice. So please can someone clarify where I can find the TDP for each motherboard, and maybe recommend some boards that will actually support this CPU.
Thanks in advance for your time guys.
switch
switch
