Hi,
Currently have the following motherboard/Cpu combo
Gigabyte GA-M68M-S2P GeForce 7025 Socket AM2+
AMD Sempron 140 2.70GHz (Socket AM3) Processor - Retail
I was using the above system as a server, but now I'm making into a 2nd gaming machine for my son and so going to replace the CPU. Having looked at what is supported I've narrowed it down to two choices.
1 - AMD Phenom II X2 Dual Core 555 3.20GHz Black Edition (Socket AM3)
2 - AMD Athlon II X4 Quad Core 640 3.00GHz (Socket AM3)
They are a similar price and so can anyone recommend which is preferred.
This will be for pretty much games only. I'll be paring it up with a mid range graphics card.
Existing Components
Coolermaster Elite 335 Case - Black
Corsair CX 400W ATX Power Supply (CMPSU-400CXUK)
Kingston 2GB (1x2GB) DDR2 PC2-6400C6 800MHz Single Channel Memory Module
Monitor will be 1600x900 Resolution
Existing Components
