AMD CPU's question
4 Feb 2007
Nuneaton, UK
When I got my 1st AMD it was a 2000+ stock speed was 1.67Ghz i think, they supposed to have called it the 2000 as it was meant to equal the speed of a 2Ghz pentium cpu, i then had an over clocked 1700+ stock speed was 1.5Ghz so they were fairly close. But now I see AMD 4200 only being 2.4Ghz, is this meant to be as fast as a 4Ghz pentium? They seem to be well off the mark now, I used to like AMD, not anymore, doubt I will ever go back.
Am I very wrong? if so please point me in the right direction.
Thanks
sorry to say but yes, very wrong indeed, athlon 64s are even more efficient clock for clock than the old XPs and 2000+ and so on, the 4200+ are dual-core as well, so basically two K8 cores running at 2.4Ghz, clock speed means nothing
