AMD Crossfire and Mantle issues
23 Dec 2013
North Wales
As the title suggests i'm trying to get Mantle to work ok with my crossfired 280x's. I am using Thief which does have the Mantle and Mantle Crossfire settings, however when i enable "Mantle" and "Mantle Crossfire" and try to run the game it opens then just immediately closes. I then tried turning off "Mantle Crossfire" leaving just "Mantle" enabled. That also does the same thing.
I have tried:
  • Completely removing the AMD drivers and downgrading to earlier versions
  • Completely removing and reinstalling
  • Reviewing Crossfire settings
  • Googling for answers
This warning appears in the event viewer when i try and run Thief:
Log Name: System
Source: Microsoft-Windows-UserModePowerService
Date: 04/10/2014 19:23:11
Event ID: 12
Task Category: (10)
Level: Information
Keywords:
User: SYSTEM
Computer: BENW-PC
Description:
Process C:\Windows\System32\svchost.exe (process ID:3612) reset policy scheme from {8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c} to {8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c}
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-UserModePowerService" Guid="{CE8DEE0B-D539-4000-B0F8-77BED049C590}" />
<EventID>12</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>10</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2014-10-04T18:23:11.168674700Z" />
<EventRecordID>39426</EventRecordID>
<Correlation />
<Execution ProcessID="904" ThreadID="3964" />
<Channel>System</Channel>
<Computer>BENW-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="ProcessPath">C:\Windows\System32\svchost.exe</Data>
<Data Name="ProcessPid">3612</Data>
<Data Name="OldSchemeGuid">{8C5E7FDA-E8BF-4A96-9A85-A6E23A8C635C}</Data>
<Data Name="NewSchemeGuid">{8C5E7FDA-E8BF-4A96-9A85-A6E23A8C635C}</Data>
</EventData>
</Event>
This is from the .dmp file that Thief produced:
Opened log file 'f:\debuglog.txt'
0:000> .sympath srv*c:\symbols*http://msdl.microsof...ownload/symbols
Symbol search path is: srv*c:\symbols*http://msdl.microsof...ownload/symbols
Expanded Symbol search path is: srv*c:\symbols*http://msdl.microsof...ownload/symbols
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred srv*c:\symbols*http://msdl.microsof...ownload/symbols
0:000> .reload;!analyze -v;r;kv;lmnt;.logclose;q
* Exception Analysis *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for avcuf64.dll -
FAULTING_IP:
Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+cb27e
00007ff6`d7a9e02e 488b98c4000000 mov rbx,qword ptr [rax+0C4h]
EXCEPTION_RECORD: ffffffffffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 00007ff6d7a9e02e (Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0x00000000000cb27e)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 00000000000000c4
Attempt to read from address 00000000000000c4
CONTEXT: 0000000000000000 -- (.cxr 0x0;r)
.cxr 0x0;r
rax=00000000000004d9 rbx=000000000aeb1f50 rcx=000000000730aaf8
rdx=00000000072f0000 rsi=000000000aeb1f08 rdi=000000000aeb1ef8
rip=00007ffa9041248a rsp=000000000072c918 rbp=00000000000012d8
r8=00000000000004d8 r9=0000000000001988 r10=00000000073110f0
r11=000000000072d1a8 r12=000000000aeb1ef8 r13=000000000aea0080
r14=ffffffffffffffff r15=000000000aeb1f50
iopl=0 nv up ei pl nz na pe nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000202
ntdll!NtGetContextThread+0xa:
00007ffa`9041248a c3 ret
.cxr
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_READ
PROCESS_NAME: Shipping-ThiefGame.exe
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 00000000000000c4
READ_ADDRESS: 00000000000000c4
FOLLOWUP_IP:
APP: shipping-thiefgame.exe
ANALYSIS_VERSION: 6.3.9600.17237 (debuggers(dbg).140716-0327) amd64fre
FAULTING_THREAD: 00000000000011b4
PRIMARY_PROBLEM_CLASS: NULL_CLASS_PTR_READ
BUGCHECK_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ
LAST_CONTROL_TRANSFER: from 00007ff6d7a75c16 to 00007ff6d7a9e02e
STACK_TEXT:
00000000`0072ef70 00007ff6`d7a75c16 : 00000000`0660a0c0 00000000`0072f220 00000000`00000001 00000000`00000001 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xcb27e
00000000`0072f080 00007ff6`d7a8c826 : 00000000`0660a0c0 00000000`0660a0c0 00000000`00000001 00000000`00000001 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xa2e66
00000000`0072f120 00007ff6`d7a8cc8e : 00007ff6`d94487a0 00000000`00000001 00000000`00000001 00000000`00000000 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xb9a76
00000000`0072f2c0 00007ff6`d73c7b91 : 00000000`0660a0c0 00000000`00000001 00000000`00000000 00000000`00000001 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xb9ede
00000000`0072f300 00007ff6`d7ac4a0a : 00007ff6`d928ef66 00000000`00000001 00000000`00000000 00007ff6`d9447e80 : Shipping_ThiefGame!AK::MemoryMgr::SetPoolName+0x62da1
00000000`0072f3d0 00007ff6`d7ac6293 : 00000000`0372fec0 00007ff6`d94487a0 00000000`0372fec0 00000000`00000000 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xf1c5a
00000000`0072f620 00007ff6`d7ac63da : 00000000`00872526 00000000`00000000 00000000`0000000a 00007ff6`d7250000 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xf34e3
00000000`0072f6a0 00007ff6`d7ac64ad : 00000000`00872526 00000000`0000000a 00000000`00aa7860 00000000`00aa2100 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xf362a
00000000`0072f6e0 00007ff6`d86991d3 : 00000000`00873490 00000000`00000000 00000000`00000000 00000000`00000000 : Shipping_ThiefGame!Scaleform::Render::Matrix2x4<float>::Prepend+0xf36fd
00000000`0072f720 00007ffa`8e5a16ad : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : Shipping_ThiefGame!AK::Monitor::GetTimeStamp+0x250ed3
00000000`0072f7d0 00007ffa`903d4409 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`0072f820 : kernel32!BaseThreadInitThunk+0xd
00000000`0072f800 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x1d
STACK_COMMAND: ~0s; .ecxr ; kb
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: shipping_thiefgame!Scaleform::Render::Matrix2x4<float>::Prepend+cb27e
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Shipping_ThiefGame
IMAGE_NAME: Shipping-ThiefGame.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 53e8d250
FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_c0000005_Shipping-ThiefGame.exe!Scaleform::Render::Matrix2x4_float_::Prepend
BUCKET_ID: APPLICATION_FAULT_NULL_CLASS_PTR_READ_shipping_thiefgame!Scaleform::Render::Matrix2x4_float_::Prepend+cb27e
ANALYSIS_SOURCE: UM
FAILURE_ID_HASH_STRING: um:null_class_ptr_read_c0000005_shipping-thiefgame.exe!scaleform::render::matrix2x4_float_::prepend
FAILURE_ID_HASH: {3fd11ad8-f29e-f1c0-5c13-ff71dff29d31}
Followup: MachineOwner
Child-SP RetAddr : Args to Child : Call Site
00000000`0072c918 00000000`00000012 : 00000000`00140012 00000000`53c6e800 00000000`002a0028 00000000`53c6ee58 : ntdll!NtGetContextThread+0xa
00000000`0072c920 00000000`00140012 : 00000000`53c6e800 00000000`002a0028 00000000`53c6ee58 00000000`00000002 : 0x12
00000000`0072c928 00000000`53c6e800 : 00000000`002a0028 00000000`53c6ee58 00000000`00000002 00000000`0072c9e0 : 0x140012
00000000`0072c930 00000000`002a0028 : 00000000`53c6ee58 00000000`00000002 00000000`0072c9e0 00000000`00000000 : avcuf64!AvcGetJumpCode+0x5d780
00000000`0072c938 00000000`53c6ee58 : 00000000`00000002 00000000`0072c9e0 00000000`00000000 00000000`00000000 : 0x2a0028
00000000`0072c940 00000000`00000002 : 00000000`0072c9e0 00000000`00000000 00000000`00000000 00000000`0072c9a0 : avcuf64!AvcGetJumpCode+0x5ddd8
00000000`0072c948 00000000`0072c9e0 : 00000000`00000000 00000000`00000000 00000000`0072c9a0 00000000`53c1a7bd : 0x2
00000000`0072c950 00000000`00000000 : 00000000`00000000 00000000`0072c9a0 00000000`53c1a7bd 00000000`0072d470 : 0x72c9e0
start end module name
00000000`51770000 00000000`517d3000 vstdlib_s64 vstdlib_s64.dll Tue Sep 23 04:17:08 2014 (5420E634)
00000000`517e0000 00000000`51904000 tier0_s64 tier0_s64.dll Tue Sep 23 04:16:53 2014 (5420E625)
00000000`51910000 00000000`5247c000 steamclient64 steamclient64.dll Tue Sep 23 04:18:17 2014 (5420E679)
00000000`52480000 00000000`52552000 msvcr100 msvcr100.dll Sat Jun 11 01:54:04 2011 (4DF2BCAC)
00000000`52560000 00000000`525f8000 msvcp100 msvcp100.dll Sat Jun 11 01:54:26 2011 (4DF2BCC2)
00000000`52600000 00000000`52621000 steam_api64 steam_api64.dll Mon Feb 25 19:43:54 2013 (512BBEFA)
00000000`53c10000 00000000`53ca2000 avcuf64 avcuf64.dll Mon Aug 25 08:47:22 2014 (53FAEA0A)
00000001`80000000 00000001`80033000 tbbmalloc tbbmalloc.dll Mon Dec 03 18:10:20 2012 (50BCEB0C)
00007ff6`d7250000 00007ff6`d9c43000 Shipping_ThiefGame Shipping-ThiefGame.exe Mon Aug 11 15:25:20 2014 (53E8D250)
00007ffa`6e600000 00007ffa`6eb67000 amdmantle64 amdmantle64.dll Mon Sep 15 23:08:59 2014 (5417637B)
00007ffa`6eb70000 00007ffa`6eee5000 PhysX3_x64 PhysX3_x64.dll Fri Jan 03 15:50:44 2014 (52C6DC54)
00007ffa`72080000 00007ffa`722ef000 D3DCOMPILER_43 D3DCOMPILER_43.dll Fri May 21 23:40:43 2010 (4BF70BEB)
00007ffa`72ad0000 00007ffa`72af5000 ltc_help64_86352 ltc_help64-86352.dll Wed Aug 20 02:28:45 2014 (53F3F9CD)
00007ffa`74640000 00007ffa`74789000 gameoverlayrenderer64 gameoverlayrenderer64.dll Tue Sep 23 04:17:16 2014 (5420E63C)
00007ffa`74a30000 00007ffa`74bb8000 dbghelp dbghelp.dll Mon Jan 27 17:18:48 2014 (52E694F8)
00007ffa`74c60000 00007ffa`74e5a000 PhysX3Common_x64 PhysX3Common_x64.dll Fri Jan 03 15:50:37 2014 (52C6DC4D)
00007ffa`76810000 00007ffa`76856000 d3dx11_43 d3dx11_43.dll Fri May 21 23:41:05 2010 (4BF70C01)
00007ffa`78590000 00007ffa`785b4000 mantle64 mantle64.dll Mon Sep 15 23:09:10 2014 (54176386)
00007ffa`785c0000 00007ffa`78600000 dinput8 dinput8.dll Thu Aug 22 12:28:43 2013 (5215F5EB)
00007ffa`7dbf0000 00007ffa`7dc0c000 MantleAxl64 MantleAxl64.dll Mon Sep 15 23:03:12 2014 (54176220)
00007ffa`86fa0000 00007ffa`86fa9000 wsock32 wsock32.dll Thu Aug 22 12:34:17 2013 (5215F739)
00007ffa`875f0000 00007ffa`87727000 atiadlxx atiadlxx.dll Mon Sep 15 22:59:20 2014 (54176138)
00007ffa`88120000 00007ffa`8812b000 secur32 secur32.dll Thu Aug 22 11:05:44 2013 (5215E278)
00007ffa`88d70000 00007ffa`8901f000 iertutil iertutil.dll Sat Aug 16 03:00:30 2014 (53EEBB3E)
00007ffa`89020000 00007ffa`8925b000 wininet wininet.dll Sat Aug 16 01:56:13 2014 (53EEAC2D)
00007ffa`897f0000 00007ffa`8995f000 propsys propsys.dll Sat Aug 16 03:12:15 2014 (53EEBDFF)
00007ffa`8b620000 00007ffa`8b69f000 dxgi dxgi.dll Sat Jun 07 09:39:11 2014 (5392CFAF)
00007ffa`8ba70000 00007ffa`8ba90000 dwmapi dwmapi.dll Sun Apr 06 12:31:33 2014 (53413B15)
00007ffa`8bc40000 00007ffa`8bc4a000 version version.dll Thu Aug 22 12:34:18 2013 (5215F73A)
00007ffa`8bc50000 00007ffa`8bcef000 SHCore SHCore.dll Sat Feb 22 09:30:03 2014 (53086E1B)
00007ffa`8c310000 00007ffa`8c33a000 WINMMBASE WINMMBASE.dll Thu Aug 22 10:47:02 2013 (5215DE16)
00007ffa`8c340000 00007ffa`8c34a000 winnsi winnsi.dll Thu Aug 22 11:05:45 2013 (5215E279)
00007ffa`8c350000 00007ffa`8c36f000 winmm winmm.dll Thu Aug 22 10:41:05 2013 (5215DCB1)
00007ffa`8c370000 00007ffa`8c381000 wtsapi32 wtsapi32.dll Thu Aug 22 12:31:54 2013 (5215F6AA)
00007ffa`8c390000 00007ffa`8c3b9000 IPHLPAPI IPHLPAPI.DLL Thu Aug 22 11:05:30 2013 (5215E26A)
00007ffa`8c400000 00007ffa`8c521000 uxtheme uxtheme.dll Sat Feb 22 12:22:18 2014 (5308967A)
00007ffa`8c580000 00007ffa`8c58a000 kernel_appcore kernel.appcore.dll Thu Aug 22 11:01:32 2013 (5215E17C)
00007ffa`8c590000 00007ffa`8c5b6000 devobj devobj.dll Thu Aug 22 10:59:51 2013 (5215E117)
00007ffa`8cd70000 00007ffa`8cd8e000 userenv userenv.dll Thu Mar 06 06:55:11 2014 (53181BCF)
00007ffa`8d540000 00007ffa`8d56b000 sspicli sspicli.dll Sat Sep 21 07:09:28 2013 (523D3818)
00007ffa`8d570000 00007ffa`8d5d0000 bcryptPrimitives bcryptPrimitives.dll Sat Feb 22 09:57:57 2014 (530874A5)
00007ffa`8d5d0000 00007ffa`8d5da000 CRYPTBASE CRYPTBASE.dll Thu Aug 22 12:37:07 2013 (5215F7E3)
00007ffa`8d700000 00007ffa`8d714000 profapi profapi.dll Thu Aug 22 11:05:23 2013 (5215E263)
00007ffa`8d7b0000 00007ffa`8d7c2000 msasn1 msasn1.dll Thu Aug 22 11:06:00 2013 (5215E288)
00007ffa`8d7d0000 00007ffa`8d9a7000 crypt32 crypt32.dll Wed Oct 16 12:09:31 2013 (525E73EB)
00007ffa`8d9b0000 00007ffa`8d9fa000 cfgmgr32 cfgmgr32.dll Thu Aug 22 11:04:46 2013 (5215E23E)
00007ffa`8da00000 00007ffa`8db0f000 KERNELBASE KERNELBASE.dll Sat Aug 16 03:17:18 2014 (53EEBF2E)
00007ffa`8db10000 00007ffa`8db5c000 wintrust wintrust.dll Mon Mar 31 00:10:08 2014 (5338A450)
00007ffa`8dc20000 00007ffa`8dd98000 ole32 ole32.dll Sat Mar 08 06:11:47 2014 (531AB4A3)
00007ffa`8dda0000 00007ffa`8dee4000 gdi32 gdi32.dll Sat Aug 02 05:29:30 2014 (53DC692A)
00007ffa`8def0000 00007ffa`8df05000 imagehlp imagehlp.dll Sat Oct 19 05:14:34 2013 (5262072A)
00007ffa`8df10000 00007ffa`8e049000 msctf msctf.dll Sat Feb 22 09:46:18 2014 (530871EA)
00007ffa`8e1f0000 00007ffa`8e247000 sechost sechost.dll Thu Aug 22 12:38:53 2013 (5215F84D)
00007ffa`8e250000 00007ffa`8e284000 imm32 imm32.dll Sat Feb 22 09:46:34 2014 (530871FA)
00007ffa`8e390000 00007ffa`8e4c7000 rpcrt4 rpcrt4.dll Fri Jun 20 00:55:40 2014 (53A3787C)
00007ffa`8e4d0000 00007ffa`8e574000 clbcatq clbcatq.dll Thu Aug 22 10:12:16 2013 (5215D5F0)
00007ffa`8e580000 00007ffa`8e587000 psapi psapi.dll Thu Aug 22 11:05:49 2013 (5215E27D)
00007ffa`8e5a0000 00007ffa`8e6da000 kernel32 kernel32.dll Thu Mar 20 01:17:16 2014 (532A419C)
00007ffa`8e6e0000 00007ffa`8e731000 shlwapi shlwapi.dll Thu Aug 22 10:08:52 2013 (5215D524)
00007ffa`8e740000 00007ffa`8e798000 ws2_32 ws2_32.dll Thu Aug 22 11:04:54 2013 (5215E246)
00007ffa`8e7a0000 00007ffa`8e911000 user32 user32.dll Sat Feb 22 09:47:41 2014 (5308723D)
00007ffa`8e920000 00007ffa`8e9c7000 msvcrt msvcrt.dll Thu Aug 22 12:43:00 2013 (5215F944)
00007ffa`8e9d0000 00007ffa`8fddf000 shell32 shell32.dll Sat Aug 16 01:39:10 2014 (53EEA82E)
00007ffa`8fde0000 00007ffa`8ffb6000 combase combase.dll Sat Feb 22 10:13:59 2014 (53087867)
00007ffa`8ffc0000 00007ffa`90065000 advapi32 advapi32.dll Sat Feb 22 12:01:54 2014 (530891B2)
00007ffa`90070000 00007ffa`90127000 oleaut32 oleaut32.dll Tue Jan 07 23:43:31 2014 (52CC9123)
00007ffa`90130000 00007ffa`90304000 setupapi setupapi.dll Sat Feb 22 08:48:55 2014 (53086477)
00007ffa`90370000 00007ffa`90379000 nsi nsi.dll Thu Aug 22 12:41:41 2013 (5215F8F5)
00007ffa`90380000 00007ffa`90526000 ntdll ntdll.dll Sat Aug 16 03:08:34 2014 (53EEBD22)
Closing open log file f:\debuglog.txt
and finally this is the log file produced by Thief:
00:07:45:993 (4492) > THIEF (64-bit)
00:07:45:994 (4492) > ==============
00:07:45:995 (4492) >
00:07:45:995 (4492) > Memory statistics:
00:07:45:997 (4492) > Total RAM = 7.9 GB (8107 MB)
00:07:45:997 (4492) > Avail RAM = 5.1 GB (5178 MB)
00:07:45:997 (4492) > Total virtual memory = 131072.0 GB (134217727 MB)
00:07:45:998 (4492) > Avail virtual memory = 131071.8 GB (134217514 MB)
00:07:45:998 (4492) > OS = Windows 8 (build 9200)
00:07:46:004 (4492) > [Main] Version: 1.6 build 4158.14
00:07:46:004 (4492) > [Main] Command line: -nolauncher
00:07:46:005 (4492) > [Main] Base directory: F:\Steam\steamapps\common\Thief\Binaries2\Win64\
00:07:46:117 (4492) > [Platform] CPU Page size=4096, Processors=8
00:07:46:118 (4492) > [Platform] High frequency timer resolution =14.318180 MHz
00:07:46:120 (4492) > [CPUCount] -----------------------------------------
00:07:46:120 (4492) > [CPUCount] GetLogicalProcessorInformation results:
00:07:46:121 (4492) > [CPUCount] -----------------------------------------
00:07:46:121 (4492) > [CPUCount] Number of NUMA nodes: 1
00:07:46:122 (4492) > [CPUCount] Number of physical processor packages: 1
00:07:46:122 (4492) > [CPUCount] Number of processor cores: 4
00:07:46:123 (4492) > [CPUCount] Number of logical processors: 8
00:07:46:123 (4492) > [CPUCount] Number of processor L1/L2/L3 caches: 12/4/1
00:07:46:194 (4492) > [Render] NxApp PreInit
00:07:46:195 (4492) > [Render] Enumerating adapters:
00:07:46:196 (4492) > [Render] Adapter 0:
00:07:46:196 (4492) > Description : AMD Radeon R9 200 Series
00:07:46:197 (4492) > Vendor : AMD (1002)
00:07:46:197 (4492) > Device : 6798
00:07:46:198 (4492) > Sub system : 30011787
00:07:46:198 (4492) > Revision : 0
00:07:46:199 (4492) > Dedicated Video Memory : 6101 MB
00:07:46:199 (4492) > Dedicated System Memory : 0000 MB
00:07:46:200 (4492) > Shared System Memory : 3840 MB
00:07:46:201 (4492) > [Render] Loading ADL...
00:07:46:220 (4492) > [Render] CROSSFIRE GPU count query failed, no multi-gpu optimizations.
00:07:46:220 (4492) > [Render] Done loading ADL and AGS
00:07:46:221 (4492) > [Render] Adapter 1:
00:07:46:221 (4492) > Description : Microsoft Basic Render Driver
00:07:46:222 (4492) > Vendor : Unknown (1414)
00:07:46:222 (4492) > Device : 8c
00:07:46:223 (4492) > Sub system : 0
00:07:46:223 (4492) > Revision : 0
00:07:46:224 (4492) > Dedicated Video Memory : 0000 MB
00:07:46:224 (4492) > Dedicated System Memory : 0000 MB
00:07:46:225 (4492) > Shared System Memory : 0256 MB
00:07:46:226 (4492) >
00:07:46:226 (4492) > [Render] Enumerating monitors:
00:07:46:227 (4492) > [Render] Monitor 0: handle = 0000000000010001, aspect = 1.78
00:07:46:338 (4492) > [Render] AMD HD3D Extension created.
00:07:46:338 (4492) > [Render] AMD HD3D Extension Version: 8.1
00:07:46:339 (4492) > [Render] AMD HD3D failed to initialize. (Most likely cause: there is no 3D support)
00:07:46:339 (4492) > [Render] AMD HD3D: Released Quad Buffer Stereo Extension.
00:07:46:340 (4492) > [Render] Enumerating Display Modes:
00:07:46:348 (4492) > [Render] Querying ADL for Eyefinity modes
00:07:46:353 (4492) > [Render] ADL_Display_DisplayMapConfig_Get() failed
00:07:46:353 (4492) > [Render] Monitor 'Display 1 (AMD Radeon R9 200 Series(1))' (0000000000010001):
00:07:46:354 (4492) > [Render] - Mode 0 : 640 x 480 @ 67 Hz, stereo = 0
00:07:46:354 (4492) > [Render] - Mode 1 : 640 x 480 @ 72 Hz, stereo = 0
00:07:46:355 (4492) > [Render] - Mode 2 : 640 x 480 @ 75 Hz, stereo = 0
00:07:46:355 (4492) > [Render] - Mode 3 : 640 x 480 @ 60 Hz, stereo = 0
00:07:46:356 (4492) > [Render] - Mode 4 : 720 x 480 @ 56 Hz, stereo = 0
00:07:46:356 (4492) > [Render] - Mode 5 : 720 x 480 @ 56 Hz, stereo = 0
00:07:46:357 (4492) > [Render] - Mode 6 : 720 x 480 @ 60 Hz, stereo = 0
00:07:46:357 (4492) > [Render] - Mode 7 : 720 x 480 @ 72 Hz, stereo = 0
00:07:46:358 (4492) > [Render] - Mode 8 : 720 x 480 @ 72 Hz, stereo = 0
00:07:46:358 (4492) > [Render] - Mode 9 : 720 x 480 @ 75 Hz, stereo = 0
00:07:46:359 (4492) > [Render] - Mode 10 : 720 x 480 @ 75 Hz, stereo = 0
00:07:46:359 (4492) > [Render] - Mode 11 : 720 x 576 @ 56 Hz, stereo = 0
00:07:46:360 (4492) > [Render] - Mode 12 : 720 x 576 @ 56 Hz, stereo = 0
00:07:46:361 (4492) > [Render] - Mode 13 : 720 x 576 @ 60 Hz, stereo = 0
00:07:46:361 (4492) > [Render] - Mode 14 : 720 x 576 @ 60 Hz, stereo = 0
00:07:46:362 (4492) > [Render] - Mode 15 : 720 x 576 @ 72 Hz, stereo = 0
00:07:46:362 (4492) > [Render] - Mode 16 : 720 x 576 @ 72 Hz, stereo = 0
00:07:46:362 (4492) > [Render] - Mode 17 : 720 x 576 @ 75 Hz, stereo = 0
00:07:46:363 (4492) > [Render] - Mode 18 : 720 x 576 @ 75 Hz, stereo = 0
00:07:46:364 (4492) > [Render] - Mode 19 : 800 x 600 @ 56 Hz, stereo = 0
00:07:46:364 (4492) > [Render] - Mode 20 : 800 x 600 @ 60 Hz, stereo = 0
00:07:46:365 (4492) > [Render] - Mode 21 : 800 x 600 @ 72 Hz, stereo = 0
00:07:46:365 (4492) > [Render] - Mode 22 : 800 x 600 @ 75 Hz, stereo = 0
00:07:46:366 (4492) > [Render] - Mode 23 : 1024 x 768 @ 60 Hz, stereo = 0
00:07:46:366 (4492) > [Render] - Mode 24 : 1024 x 768 @ 70 Hz, stereo = 0
00:07:46:367 (4492) > [Render] - Mode 25 : 1024 x 768 @ 75 Hz, stereo = 0
00:07:46:367 (4492) > [Render] - Mode 26 : 1280 x 720 @ 50 Hz, stereo = 0
00:07:46:368 (4492) > [Render] - Mode 27 : 1280 x 720 @ 60 Hz, stereo = 0
00:07:46:368 (4492) > [Render] - Mode 28 : 1280 x 768 @ 60 Hz, stereo = 0
00:07:46:369 (4492) > [Render] - Mode 29 : 1280 x 768 @ 60 Hz, stereo = 0
00:07:46:369 (4492) > [Render] - Mode 30 : 1280 x 800 @ 60 Hz, stereo = 0
00:07:46:370 (4492) > [Render] - Mode 31 : 1280 x 800 @ 60 Hz, stereo = 0
00:07:46:370 (4492) > [Render] - Mode 32 : 1280 x 960 @ 60 Hz, stereo = 0
00:07:46:371 (4492) > [Render] - Mode 33 : 1280 x 1024 @ 60 Hz, stereo = 0
00:07:46:371 (4492) > [Render] - Mode 34 : 1280 x 1024 @ 75 Hz, stereo = 0
00:07:46:372 (4492) > [Render] - Mode 35 : 1360 x 768 @ 60 Hz, stereo = 0
00:07:46:372 (4492) > [Render] - Mode 36 : 1360 x 768 @ 60 Hz, stereo = 0
00:07:46:373 (4492) > [Render] - Mode 37 : 1360 x 1024 @ 60 Hz, stereo = 0
00:07:46:373 (4492) > [Render] - Mode 38 : 1360 x 1024 @ 60 Hz, stereo = 0
00:07:46:374 (4492) > [Render] - Mode 39 : 1366 x 768 @ 60 Hz, stereo = 0
00:07:46:374 (4492) > [Render] - Mode 40 : 1366 x 768 @ 60 Hz, stereo = 0
00:07:46:375 (4492) > [Render] - Mode 41 : 1440 x 900 @ 60 Hz, stereo = 0
00:07:46:375 (4492) > [Render] - Mode 42 : 1600 x 900 @ 60 Hz, stereo = 0
00:07:46:376 (4492) > [Render] - Mode 43 : 1600 x 900 @ 60 Hz, stereo = 0
00:07:46:376 (4492) > [Render] - Mode 44 : 1680 x 1050 @ 60 Hz, stereo = 0
00:07:46:377 (4492) > [Render] - Mode 45 : 1920 x 1080 @ 50 Hz, stereo = 0
00:07:46:377 (4492) > [Render] - Mode 46 : 1920 x 1080 @ 60 Hz, stereo = 0
00:07:46:378 (4492) >
00:07:46:701 (4492) > [render] GPU Compatibility Flags (0/1): 007f (Y)
00:07:46:804 (4492) > [Render] Mantle dlls found!
00:07:47:002 (4492) > [render] GPU 0: AMD Radeon R9 200 Series (type 12290), 1050.000000,32.000000,32.000000,2.000000,32.000000
00:07:47:003 (4492) > [render] GPU 1: AMD Radeon R9 200 Series (type 12290), 1080.000000,32.000000,32.000000,2.000000,32.000000
00:07:47:004 (4492) > [render] GPU Compatibility Flags (0/1): 007f (Y)
00:07:47:004 (4492) > [render] Match (102900.000000-208740.000000-104370.000000,2) 1100000000000000
00:07:47:005 (4492) > [render] Match (105840.000000-105840.000000-105840.000000,1) 0100000000000000
00:07:47:005 (4492) > [render] Best match (105840.000000-105840.000000-105840.000000,1) 0100000000000000
00:07:47:106 (4492) > [render] recreateTargets:1
00:07:47:106 (4492) > [render] recreating backbuffers
00:07:47:107 (4492) > [render] Created Manual Backbuffer Images for GPU 1.
00:07:47:108 (4492) > [Render] Using constrained texture memory pool size of 409MB. (VRAM:0MB)
00:07:47:332 (4492) > [Crash] Game crashed with exception: 0xc0000005
Not sure what else to do! HELP?!?!?! :D
I have 14.9. Have tried several different versions. 14.4, 14.7 and now 14.9. It does the same and gives the error and dump file.
Ok lets dig deep.
Have you used DDU before? Display Driver Uninstaller?
Download from here
http://forums.guru3d.com/showthread.php?t=379505
Run it and it will do a system restore backup, then when asked to boot into safe mode say yes
Now select AMD, and Recommended setting and run, after finish PC will restart.
Now you have completely removed all drivers for GPU
Install 14.9 again and restart once more when asked.
Test again
Am not sure what else then. Reading into the Logs I see Memory errors have you tested your RAM with Memtest?
Have you run a check on the game files in steam?
Had any BSOD lately?
Ran memtest and it came back clean. Ran an integrity check on the game files and those were fine too and i have not had any BSOD.
I only play BF4 on my 7990. Mantle gives me nothing but problems from cpu spikes, driver crashes 14.9's, BF4 freezing.
Back to DX11 played 5 hours with not one single issue.
Given up with Mantle.
I'm afraid i can't analyze a Thief mini dump file nor would i know how to read the information. However i have some links that should enable you to get help from the Thief community and game developers.
Forum Link
http://forums.eidosgames.com/forumdisplay.php?f=317
Support
You can get official Nixxes support below
http://support.eu.square-enix.com/
Thanks for the reply, ye it is a wall of text and not very understandable.
EVERY game i use with Mantle does this and/or force closes. Not sure whether it is a driver problem or coincidentally a software issue.
I see you've already tried reinstalling drivers, next step might be to try a fresh windows install as perhaps something is affecting your system. Submit your Thief dmp file to Nixxes, perhaps they can analyze and give us an indication of what the problem is.
I noticed on the Release Notes for 14.9 it says one of the known issues is:
[405432]: Mantle driver will TDR when running Star Swarm on the loading screen
Sorry for being dumb but what does TDR stand for?
Ok, would that be shown as the program not responding? That's what happens when try and run Star Swarm in Mantle.
EDIT: The cards came factory overclocked to 1080 and the other 1050.
