Let me set the scene...
I had issues not long ago where my old old old SSD was causing system crashes and I eventually tracked it down and removed the bad SSD. Since then, my system has been running like a dream.
While I was trying to find the original problem I turned off crossfire and ran only one 290 - thinking one of the cards might of been the problem. Since that was months ago I had forgot to turn crossfire back on. So tonight I turned it back on and do some Arma3 - all good.
Now I've started getting system crashes (or at least I think it's a crash). Screen just goes black and I can't do anything, completely unresponsive.
I'm thinking it's way too much of a coincidence that a few hours prior I had turned crossfire back on. I've now turned crossfire off again and running the system as per normal to see if the problem stops.
I'm thinking the card must have issues - Just wanted to check there are no known issues with drivers that could cause this?
* I should add all crashes so far have just been browsing the web - not even in game.
Thanks
Thanks
