AMD Drivers help
15 Jul 2007
South West
So im new to using AMD and im having difficulty in working out how to assign settings for a particular game.
Im using 3D application settings, then selecting my settings ie AA, override application, i then save it using the games exe.
When playing the game for that profile i have saved all is fine and working.
Trouble is every other game i play uses the same settings i have saved for that particular game, so i have to set back to defaults every time to play other games, if not AA X8 (Override is selected for everygame.
Why arent other games playing with default settings and using this 1 game i have saved a profile for?
Is this normal ?
You must set 3D setting back to default after you have made the settings and saved for a game.exe.
You should then be able to click the <<New Application>> button and see your saved profiles.
Radon pro has not been updated in a while and has issues with the new drivers.
To be honest, it worked ok for me when I tried it, don't use it now, I don't think it will be updated now cus the author has moved to nvidia.
Indeed and it could be said that if he didn't then AMD may not have introduced there own, but that just a theory that crept into my mind.
For anyone having problems with their GPU clock getting stuck at 501Mhz in Xfire in the 12.2's and later having a browser page open causes this. Close it and it will clock back up. Thought it would be fixed by 12.4 WHQL but it's not.
