AMD drivers - I keep having problems installing them... 2×7990 [SOLVED]
I have two 7990s in crossfire and every time I need to update/install AMD drivers, the catalyst installer freezes the PC when it comes to installing gpu drivers.
First I had a problem with the uninstaller as it was saying something I've never seen before and I've seen things... unfortunately didn't write it down. I managed to uninstall ccc using installer (used driver uninstaller from 3d guru and it worked fine) and then installed the latest 14.1 version. It doesn't matter what version I'm installing and what windows (7, 8, 8.1, fresh installs), the installer always freezes when it comes to installing drivers and I always end up resetting the PC.
After few times of doing it, the latest drivers appeared to be installed in device manager (showing the latest version), but ccc installer says otherwise:
I can't easily remove one card as they are watercooled, but this thing is getting on my nerves now...
Anyway, the drivers appears to be installed, only ccc installer thinks otherwise and if I try to install drivers via ccc installer, the PC will crash. It did show 0xB3 BSOD once during drivers installation. Something to do with memory? I have a LCD in my keyboard and when the installation freezes, I can see billions of megabytes used by GPU RAM, this is when I need to press reset button.
Crossfire seems to be working fine too, but I face those crashes EVERY time I get to install new drivers...
No GPU overclock. (only CPU is OCed, but I do not believe it is CPU related)
Any ideas?
Any ideas?
