AMD Drivers- Whats going on
7 Jan 2009
Anyone been having problems with all of AMDs latest drivers as of 11.1 onwards?
The drivers seem to have gone downhill imo since AMD took over Ati :mad:
Im talkin about in games such as BC2,Bulletstorm etc...all are performing laggy/slugish.
BC2 use to run very nice ony my rig,In the 80fps+ range and now im lucky to see 55 and just like i said slugish performance.
Just courius to see if im the only one having problems. :p
I have had no problems with my 6870. I have used 10.12,11.1,11.2 and now the 11.4 whql. I did have problems trying out the 11.4 betas though which gave me a rainbow like effect on dark colours in all my games. I put that down to them being betas though and now the 11.4 officials are working great.
i'm getting the odd weirdness with the 11.4's with my 5970+5870;
1) whenever there is water in l4d2 (no mercy sewers, swamp fever etc), gpu usage (and so fps) drops
2) if i drag my cursor to the top right of my desktop, it judders around in one small area
3) i get random freezing every so often whilst using firefox, as in mouse won't move, clock doesn't tick on etc, but it's fine after a second or 2.
on the flip side, with overdrive enabled and using eyefinity, idle clock speeds are down to 157/300 :)
with every driver i used since 10.10 (excluding these) i had an annoying flickering on the outer 2 monitors, so it's a worthy trade off i guess considering minimum fps has been slightly improved since 10.10's
It sounds like your running every possible thing that AMD have problems with.
Crossfire, 5970 + a 5870, tripple monitor etc..... Just just that, but all together! Your gona get some weirdness that for sure.
