Hi,
I'm hoping someone here will be able to help me. I'm having an issue at the moment with my CPU idling at high temps and causing system shutdowns due to overheating when under load.
To give an example of the types of temperatures I'm getting, I benched my tower for testing a couple of days ago, with both sides off and all fans set to 100% speed, with the PC sat in the BIOS I was idling at 49 degrees. Going into an OS bumped the idle temperature to 60+ degrees
Some relevant details:
CPU: AMD FX 8120 - NOT OC'd - Using BIOS defaults. Voltage is currently at 1.380.
Motherboard: ASUS Sabertooth 990FX - BIOS fully updated.
Heatsink/Fan: Arctic Freezer 13
My case is a Coolermaster Silencio 550, I have 2 120mm fans mounted on the front (also removed the front door for better cooling) that are positioned to both draw air into the case, a 120mm fan mounted on the rear to expel air and I've also machined an extra grill onto the top of the case, directly above the heatsink with another 120mm fan expelling air.
The CPU/Heatsink have been removed, old thermal paste removed from both and a fresh layer applied, the thermal paste used is Arctic Silver 5, with a small drop applied, and then spread in a thin layer to give 100% coverage of the contact area, there is no excess paste. The CPU/Heatsink have been reseated and have a solid, complete contact.
All fans/vents/heatsink/case internals etc... have been cleaned out and are completely dust free. Internal cabling has been routed/tied back to allow maximum possible air flow through the case. The case is positioned on the floor but is raised by a couple of pieces of wood to allow air flow under the case, it is not obstructed on any side and is not positioned near any external heat sources.
I have underclocked the CPU as well as reducing the voltage, this only made a couple of degrees of difference to the temperature, and not enough to prevent the overheating while under load. As mentioned above, the case has been tested with the sides off, and again whilst the temperature dropped a couple of degrees the difference was only marginal (we're talking 49 degrees idle in BIOS with sides off vs 52 degrees with sides on).
I'm utterly at a loss as to what could be the problem, any help/advice would be much appreciated and if any more information about my setup is required please feel free to ask.
Kind regards
Gerry
Kind regards
Gerry
