AMD GPU's for AI (LLM's, Stable Diffusion etc)
5 Jan 2025
The Moon
Does anyone have experience of using AMD GPU's for offline AI?
I'm currently running a 10gb RTX 3080 in my SFF living room PC connected to a 4k LG OLED TV. I use the PC for a mix of media consumption, gaming (recently discovered Helldivers 2), and some AI (mostly text-generation in LM Studio). The whole thing runs seamlessly, but I'm ready to take things up a notch. I'm willing to consider the upcoming 9070 XT, given its 16gb's of VRAM and (potentially) 7900xt/4080 levels of raster (as well as the improved RT, which would look great on this TV).
My one concern are the number of conflicting reports I have read online about people struggling to get LLM's running on AMD.
Anyone here that can share their experience of AI on AMD?
ROCm is something to look into, I do know it has some AI capabilities (not something I've ever looked into tbh).
Thanks for the reply. I have looked into it but it's hard to get a consensus answer. Was hoping people here might have some real-world experience they can share. It's going to be a decisive factor in my next purchase but I don't want to pay over the odds for more VRAM!
My exp is with SD w/ an RX6800. I can tell you that it's an absolute pain to deal with on windows and you're way behind Nvidia not just in perf but also in simply getting things to work. I would absolutely avoid AMD like the plague for ML. It's for me another important factor for why I'm jumping to Nvidia with 5000 series.
Thanks, Poneros. This confirms my fears about going AMD. Now if only I could get a decent amount of VRAM in a SFF! Probably going to have to go for a used 4070ti Super if the 5070ti is more than about 700 quid.
My experience is the complete opposite. visit https://www.amuse-ai.com/ offline image generation works out of the box with a one click install no problem at all. No worrying about dependencies from github etc. , all your stable difusion models etc are there working fine. Even better is that if you have a integrated amd APU you get to utilise both the NPU & GPU & more importantly your sytem ram.
I've had 0 issues at all with the APU regarding speed or compatibility with ai apps. (there are plenty of legacy cuda apps that will likely cause problems though)
(fixed wrong url)
I've found LM Studio runs fine on a 5700G system, utilising the onboard GPU (although it's probably no faster than CPU only with the slow system memory).
Haven't dared try to run SD on it. :D
I know prompt processing used to be a bit slower on AMD, but no idea if that used to be the case. Worth looking on the localllama subreddit. There are a few people using 7900XTXs there. Ultimately, higher-end Nvidia cards are still the ones to have.
I've used SHARK (Stable Diffusion) on a 7900XTX, and my experience is that it mostly* works, and is fast.
* Some releases have been broken on AMD cards, and I had to revert to a previous version.
I was using a different version from the same programmer last year. Just installed this and it feels familiar but faster. This is stable diffusion don't know what LLM is.
"* Some releases have been broken on AMD cards, and I had to revert to a previous version."
This is what put me off using the version from last year. I should think it will be more stable now since zluda uses RoCM.
Thread interests me as I'm in the process of researching a new build for AI and Stable Defusion. My research immediately highlighted the struggles with AMD GPUs and getting things working, compared to NVIDIA. Although I've seen huge performance drops by using certain (later) NVIDIA drivers too, so it's not all plain sailing. That said, in doing a large amount of research for just a GPU, it looks like 4070 Ti Super is the best all rounder, VFM, etc. 4060 Ti also, as a minimum. 4090 is expensive Vs the relative performance over the 4070. However, it might be that once all the 4090 melts buy into the spiel about the 5070, that the used 4090 market lights up.
Additionally, game play for me is a valuable byproduct of whatever card I get, but it's primary objective is AI / SD. So, for me, 4070 Ti Super is the top of the shopping list.
However, that's all I've currently achieved. I now ideally want SFF case, mobo, ultra 9, a large memory ability (64Gb min) and ideally some upgradeable options should I wish to move to a 50x card in the future.
I've used ROCm for LLMs, namely Kobold. One thing I will say is that if you want to mess about with LLMs I'd say aim for as much VRAM as possible, ideally at least 24gb. If you plan on doing any fine tuning you'll want to go Nvidia but for inference AMD is fine.
If you're on Windows then NVIDIA is MUCH better, if you're on Linux then NVIDIA is still better - but not by such a great margin. You can get ROCM up and running on WSL2 with GPU passthrough; but then you run into the problem of disk IO being absolutely awful - which is a problem when you're trying to load 6GB checkpoints. ROCM and DirectML both struggle with memory reclamation; so larger more intensive models like Flux can and will go OOM and either kill your app at best case; or hard lock your OS prompting a hard reboot.
(fixed wrong url)
Have you tried your AMD GPU with an LLM?
That's a great subreddit which I too have been following. However, I've found a lot of the reports on there to be inconsistent when it comes to AMD. So I thought I'd give this forum a shot.
I've spent some more time with local AI, my 7900XT runs most of it well enough I think; but can get bogged down and run out of VRAM. I dont have an RTX to hand to compare. Note, i'm running all of this on Linux. Stuff like Llama works fine locally. I'm going to dig around with cloud based instances as they have like 48GB VRAM+ andI suspect that's where the bottleneck is.
