AMD Hydravison help?
16 Mar 2012
Chelmsford,Essex,UK
Hi i want to keep certain programs open in the same position on my monitor then read Hydravison is supposed to do this so thought great give it a try.
It lets you make invisible grids and snap your apps to them, so i tried a basic 3 app grid.
Now when i enable the grid the apps dont load (fair enough) but i thought by opening the apps they would snap back to the position but no:(
So Hydravision lets you make virtual desktops up to 9, so tried 2 on 1 monitor on the 2nd one it lets you save all your desktop settings so tried the grid again and saved, rebooted switched to that desktop, it has a rsetore option so also loads the apps that were on that desktop, but it also doesnt snap them to the grid:confused:
Am i doing something wrong? i just want to at least have the positions saved so when i open the app.s they snap into place.
Any help appreciated
