Hello
sorry for a mega long post but i have come across an issues and its driving me up the wall.
my PC Spec
4790k OC to 4.8ghz
Powercolor R9 390
Gigabyte Z97X-UD3H-BK mobo
32gb ram
i bought my PC to play racing sims and for a year it was great.. but i have now decided that i want to try and play other games on my machine.
my first monitor is quiet old and only has a DVI input so i needed a switch to flick between my PS4 or PC. i fitted a DVI to HDMI block and then ran a 3 way HDMI Splitter. i then used the HDMI out of the R9 390 and the PS4 to the HDMI Splitter. this worked great.
i have now added a second monitor on my desk. on my R9 390 i have spare 2 x DVI and 1 x Display Port. i plugged in to 1 of the spare DVI ports to the monitor and now im getting all sorts of weird and wonderful things happen
Issue 1 - 2D screen flicker. Appears to go away after a while. looking online appears to be an issue with the AMD Driver. the issue appears to be fixed with a small OC to the 2d Volts or something. which leads me to issue 2
Issue 2 - the AMD overclocking worked great on 1 monitor but now things appear to be not working. i clocked my memory from 1500 to 1595 on single monitor and you can see the graphics card on HWinfo and the AMD graphical view flicker between 150 and 1595 mhz. as soon as i install the second monitor i get no OC ability what so ever... so what ever it was before remains and locks in at that speed. so if i install the monitor at 150mhz its locks at 150mhz so runs like a dog. if i lock it at 1595 mhz it works great but now the temps are hitting 60 degrees constant. also for some reason HWinfo has a fit and volts stop showing on the GPU and Memory clock speed isnt being tracked and a few others are acting weird.
the only work around i seem to have is re-enable the onboard Intel GPU and run the second HDMI out of that. the R9 390 then does it thing as expected. and as long as i have the r9 390 as my primary monitor even if i present on the intel hdmi port the r9 390 is still doing the work and im getting solid 60fps...... i then open Gopro Studio and now that doesnt work as the intel gpu doesnt run OpenGL correctly!!!! FML!!!!
am i best to just torch my system? is there a fix for this?
cheers
Lee
my PC Spec
4790k OC to 4.8ghz
Powercolor R9 390
32gb ram
cheers
Lee
