- 11 Dec 2005
- Cheshire
Introducing our of Llano range of systems and bundles. Utilising the fantastic AMD APU with integrated Radeon graphics. With greatly reduced power consumption and dual core performance for an improved computing experience.
Xenon AMD Llano A4-3300 2.50GHz Bundle - Dual Core @ £129.98 inc VAT
Designed by experts the "Xenon AMD A4-3300 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD A4-3300 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
Bundle Specification
- CPU: AMD Llano A4-3300 2.50GHz (FM1 Socket) APU
- Motherboard: Asus A55-M LX AMD A55 (Socket FM1) DDR3 Motherboard
- RAM: 4GB DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £129.98 inc VAT.
ORDER NOW
"Primo 6000a" AMD Llano A4-3300 2.50GHz DDR3 Dual Core System @ £229.98 inc VAT
The "Primo 6000a" offers the performance needed for home and business use at a low price. The AMD Llano A4-3300 2.50GHz combined with 2GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD Llano A4-3300 2.50GHz (Socket FM1) offers multitasking performance.
- 8 Hours stressed tested and quality controlled
- 500GB hard drive gives a solid and reliable storage capacity.
- 2GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: OcUK IMP microATX case - Black
- Power Supply: OcUK Value 500W PSU
- CPU: AMD Llano A4-3300 2.50GHz (Socket FM1)
- Motherboard: AMD A55 Chipset (Socket FM1) DDR3 Motherboard
- RAM: 2GB DDR3 1333MHz
- Hard Drive: 500GB 6GB/s HDD
- Graphics Card: Onboard integrated NVIDIA GeForce 6150SE
- Sound: ALC662 6-Channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
Is this System for You?
Our most affordable system yet, perfect for any home or business. The "Primo 6000a" is ideal for the entry level user.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
Only £229.98 inc VAT.
ORDER NOW
"Primo 6100a AMD Llano A4-3300 2.50GHz DDR3 Dual Core System @ £249.98 inc VAT
The "Primo 6100a" offers the performance needed for home and business use at a low price. The AMD Llano A4-3300 2.50GHz combined with 4GB of 1600MHz DDR3 RAM, offers a quick and easy multitasking experience.
- 500GB Western Digital hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: Onboard integrated NVIDIA GeForce 7025 GPU
- Sound: ALC662 6-channel High Definition Audio CODEC
Service Package
Compact, reliable and smart. The "Primo 6100a" give you everything you need in a entry level home/business system.
Only £249.98 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
